Can the cam tunnel be machined out for a 55mm Cam?
Edit-Spelling
DART Little M Block
DART Little M Block
Oshkosh Defense-Powertrain Engineering
Insidecompracing.com
Re: DART Little M Block
Yes they can as we just machined a block last week for a 55MM cam core and we blue print bored the cam tunnel to 2.283 and used the GMP55-T babbit cam bearing or they could use a 50MM roller cam bearing in the same bore if needed.Speedster400 wrote:Can the cm unnel be machined out for a 55mm base circle?
Website is up and running
http://hinksonautomotive-cncblocks.com/
Machine shop tour
http://hinksonautomotive-cncblocks.com/shop-tour/
Monthly Specials
http://hinksonautomotive-cncblocks.com/specials/
55MM babbit cam bearings with 1 hole
Machine shop tour
Monthly Specials
- mt-engines
are you wanting to go 55mm roller bearing? or 60mm babbit?
The answer is yes, but I have only done it in the .391" raised cam, and not the .434".
