I am just a little sad I decided to do my design and not just take the dragon wheels......maybe next time
Found this on Google by searching for "Smithers wheel testing".SupStk wrote: ↑Wed Jul 31, 2019 12:34 pmIs this correct for wheel certification? In the materials section it appears to be mostly related to pharmaceuticals and chemicals.midnightbluS10 wrote: ↑Wed Jul 31, 2019 11:55 amWrong link posted above. Sorry
https://www.smithers.com/careers/our-co ... -locations
The Smithers Group would be the name I was looking for.
Mark, I like the looks of those wheels and their willingness to incorporate upgrades to your specs. Have a feeling this will turn out well. Gotta say I was skeptical at first!
SMITHERS GROUP LOGIN
Smithers Rapra MENU
Basket
Search
Automotive
Wheel Testing
Investing in wheel testing to meet or exceed client needs can help you earn the trust of both new and existing clients. Our laboratories perform precisely controlled and repeatable wheel testing to meet clients’ exact specifications. Using our wheel rim testing services for aftermarket parts will help you understand the life of the wheel, your liability position, and your warranty potential.
At our laboratories in Ravenna, Ohio and Suzhou, China, Smithers wheel testing capabilities include a number of standard and custom test options. Our wheel testing specifications cover a wide variety of industry standard tests including SAE, SFI, ABNT, ASTM and ISO as well as real-world and on-road tests such as torque retention studies. Some evaluation areas include:
Dynamic radial and cornering fatigue
Torsional fatigue
Hydrostatic burst tests
Impact testing
Strain gauging/stress analysis
Rim contour/dimensional checks
Rim flange strength
Metallurgical tests
Coatings analysis
Forensic investigation
In keeping with recent trends toward larger wheel sizes on SUVs and trucks, Smithers has invested in a new wheel testing machine that can accommodate passenger wheels up to 24 inches in diameter. The new machine has a computer controlling load, speed and deflection, and digital data storage and analysis.
The lab is fully equipped to perform a number of common wheel evaluations, including:
Fatigue Testing: Standard radial and cornering fatigue tests on all size wheels.
Impact Testing: Includes a standard 13-degee side impact test in accordance with SAE J175.
Hydrostatic Burst Testing: Using compressed water, the burst pressure of steel and alloy wheels is tested to determine the margin of safety above the rated wheel pressure.
Strain Gauging / Stress Analysis: Customized strain analysis protocols per your specific requirements.
Rim Contour / Dimensional Checks: Precise measurements of rim contour dimensions in accordance with Tire and Rim Association standards to confirm the wheel rim geometry will allow the tire to seat properly. Dimensions include rim width, drop center height, bead flange height, slope angle, and heel radius.
Metallurgical Testing: Metallurgical analysis of steel and aluminum wheels and other components.
Coatings Analysis: Evaluation of wheel coatings in accordance with ASTM standards and customized test protocols for coatings on steel wheels and alloy wheels. Standard test protocols include:
ASTM B117 - Salt Spray
ASTM D3170 - Chip Resistance
Thanks to many years of combined experience in wheel manufacturing, testing, and design, the experts at Smithers Rapra can deliver reliable, accurate testing and customized solutions for your testing needs and challenges.
CONTACT US ABOUT WHEEL TESTING >
