front end problem in 76 nova drag car
chevy art
Post by chevy art » Wed Mar 18, 2020 4:43 pm
my buddy has a 67 novs drag car that runs 9. with nitrous and 10.1 with just gasgline with brake and 625 horses with just carb. car always launches straight as an arrow comes up evenly and lifts both wheels about a foot off the groune and gradually settles down as he goes down the track(moroso trick slinky springs and 90-10 shocks in front. rear haa 14inch slicks and a ladder bar with mono leafs and sliders and good adjustable strange shocks on back. car always launches perfect and straight. . last time out the car launched and right away the right front side went down drastically and the car veered severely to the right, car sits perfect in the front at dead rest. he took the front end apart on that side and checked everything thoroughly and found nothing wrong. he replaced the springs and shock anyway(same as what was on there before), and the car still goes down(right side) drastically under takeoff load. i got in front on the car(way up the road ) and watched and it scarred me to death watching it lean towards the ground../ i suspect from the beginning that it had something to do with the rear ladder bars and adjustments(preload) problems. so far he has not found anything visibly loose except the right front bolt that holds the front of ladder bar(passenger side)> to front mount it was totally loose but still in the front mount housing. could this one loose bolt be the problem? none of the front adjusters on ladder bar moved to change preload. could there be a broken slider that we are not seeing. broken shock mount(drivers side?) (pass. side?) bad shackle. any input would be appreciated. i am going to get behind it next time we test it and see what kind of movement is on each side of ca when he take off under some power>. maybe this will tell us something. thanks for help art peterson in NY
SupStk
Re: front end problem in 76 nova drag car
Post by SupStk » Wed Mar 18, 2020 7:33 pm
First thing I'd look at is the ladder bars, brackets and heim ends. Sounds like something is broken.
Loose tube in axle housing?
Monty Frerichs
B&M Machine
chevy art
Post by chevy art » Wed Mar 18, 2020 11:32 pm
thanks sup. i have suspected since day 1 it was something in rear suspension. loose axle housing sounds like it could be a real problem if one of the tubes welds broke where it meets center section.. something to look at. will look at every little thing i hear from you guys on the forum. i myself have not gotten under the car yet, but just watched itlaunch..my buddy is only one under the car so far. my turn to go under and start looking at everything. thanks for reply chevy art
chevy art
Post by chevy art » Thu Mar 19, 2020 4:56 pm
PS it is a 67 nova not a 76 nova.definitely different suspension in front of car art
lefty o
Post by lefty o » Thu Mar 19, 2020 5:50 pm
if the front wheels are both up, and then it starts dropping one side before the other, it is definately in the back end somewhere.
chevy art
Post by chevy art » Fri Mar 20, 2020 12:04 am
right front bumper dives down hard as soon as the gas is hit. art
pitts64
Post by pitts64 » Sat Mar 21, 2020 4:42 pm
I would switch rear tires from side to side..
