where to put adjustable brake prop, valve
chevyart
Post by chevyart »
when using an adjustable proportioning valve on a drag car with all disc brakes. should the prop. valve be placed before or after a line lock for front wheels. could someone explain this one in detail and why the valve is placed where you say it should be. thanks art in NY
FC-Pilot
Re: where to put adjustable brake prop, valve
Post by FC-Pilot »
The prop valve should be for the rear wheels. You want your front wheels to lockup before your rear wheels.
6.50camaro
Post by 6.50camaro »
On my car I placed the line lock before the prop valve because , the prop vale has separate outlets for right front and left front brake lines or 1 inlet and 2 outlets for front bakes.
