Roll bar tube benders
LilRacr
Post by LilRacr »
How many guys are around that bend/fab all thier chassis parts, cages?
What tube benders are you guys using, for mild steel and Chrome moly tubing?
Where did you get them?
Thanks in advance!
-Bobby-
DCarr511
Post by DCarr511 »
http://jd2.com/
Their bender has worked great on MS and CM Tubing. call them and they will suggest a dealer to you or sell you what you need.
la360
Post by la360 »
Team Owner
Post by Team Owner »
Some catalog companies such as Speedway Motors will sell you a roll bar kit. If you ask them they will send you a catalog for free.
A true race chassis uses mandrel bent tubing =- not something bent on a muffler bender or one of them hyd tubing benders.
Anytime you kink the tubing - you put a weak spot in the bar. A mandrel pipe bender rolls the tubing around a mandrel - a die if you will, that gives it a exact shape without distorting the tubing.
A roll cage - race chassis is not something where you want to skimp on materials.
www.speedwaymotors.com I believe that Smileys also sells Roll Cage kits also. www.smileysracing.com
CoMaxRacing
Tube Benders
Post by CoMaxRacing »
I use the Pro-tools 105 HD great bender and Pro-Tools is easy to deal with. Shipping is fast also.
http://www.pro-tools.com/
