Hey guys
You know of anyone or have you ever fitted a Powerglide into a vk commodore type car.
I just bolted the box up and put the cross member in and its sweet
One problem but is that Im using a BM Pro Ratchet and the bracket the bolts to the oil pan that holds the cable wont fit. There isnt enuff room between the oil pan and the chassis rail on the VK.
I dont wanna just go belting the shit out of the chassis rail so i was hoping that you know or know someone that has done this before and has a good fix.
Trev
FATMAN OR LA360
I have only Dynoed a few Holden Engines, have very little experience with the cars themselves. I know I was able to flip the little pin for the shifter lever on the trans on my Torqueflite to the other side, and then dropped the bracket down accordingly. You might be able to do something similar. Otherwise, I am not much help .
AL...
AL...
