Need new slicks
dmatulion
Need new slicks
Post by dmatulion »
We need to buy new slicks for this season, we are running Phoenix 31X13X15 in a 3300lb 67 Nova with a small block chevy and a Lenco 4 speed. Any suggestions on manufacturer, compound, size, stiff or weak sidewall etc.?
Cobra
Post by Cobra »
Buying slicks covers a myriad of possibilities. Are you happy with the Phoenix slicks? Are you wanting to change? Please ask specific questions to narrow down what you are looking for.
dmatulion
Post by dmatulion »
They came with the car when we bought it a year ago and now they are thread bare. To answer your question, no not really, they seem to slip no matter what tire pressure we used.
Cobra
Post by Cobra »
Suspension setup is critical to the traction equation. Your slicks may be spinning because of improper suspension tuning. What are your 60' times? Does car drive straight with good handling throughout the run? Car seems a little heavy. What suspension and shock package do you have? How do you launch car, (transbrake, electronic aids, etc.), and what RPM?
dmatulion
Post by dmatulion »
the car is all steel, 60 foot 1.47, backhalfed DANA 60 5.13 coilovers, car runs straight as an arrow and handles fine. We have played with the launch RPM between 5500-6000 and loosened front shocks KONIS.The only thing we have not tried is increasing or decreasing the preload on the rear shocks.
Weatherman
Slicks
Post by Weatherman »
Back-halfed ladderbar, 4-link? What tire pressure have you been running in the previous tires? I run a chassis car (4-link) that weighs 2200 pounds. I have been running the Goodyear 32X14.5 stiff side wall (D1672 D5 Hard compound) and 60 foot 1.15. We run a tire pressure between 5 and 6 psig.
The super stock car we used to run was a heavy weight like yours and we ran the 31X14 D1823 tire (D4 medium compound) and it did well both in performance and service time. Tire pressure was between 6 & 7 psig.
Mickey Thompson slicks - try to run an M9 compound that is an aggressive compound for heavy cars.
Hope this helps.
Cobra
Post by Cobra »
Has car been scaled, and if so, what are the numbers? Have you checked all driveline angles including pinion? 60' should be much quicker.
