'The old tired driver side one rolled crooked when. U rolled it on the floor
Inside of tire is feathered bad. Outside has a wavey. Pattern on it"
When you do the alignment, check the rearend for toe in/out.
Pulling hard to right on launch
Re: Pulling hard to right on launch
Chuck L.
Hotrodding since 1955.
Injector Inspector.
Turbo Buicks in the 9's...
Injector Inspector.
I had tire slipping on the rim that caused hard right turn at launch. When my wheels were new i had them clear powder coated. Long story short the the coating on the bead was de-laminating causing the tire slippage. Got it all off on both wheels and had the slicks dry mounted. No more issues. I never run less than 10lbs tire pressure also.
Maintenance Machinist for Anheuser-Busch
