Restoring Z28 rims?
econo racer
Restoring Z28 rims?
Post by econo racer » Tue May 07, 2019 9:21 am
I have an old set of Z28 camaro 5 spoke steel rims. They need to be sand blasted inside and out. After this is done I want to spray 2 coats of primer sealer on the outside. Is it safe to do this on the inside of the rim that the tire covers? Or is that some how dangerous? I would not mount the tires back on for at least a week. They fit good under my nova with slicks.
BillK
Re: Restoring Z28 rims?
Post by BillK » Tue May 07, 2019 4:23 pm
I have seen plenty of steel wheels that are painted black in that area. I cant imagine primer hurting anything but I would probably actually put a good coat of quality black paint on them instead. They grey for the spokes is available from several sources if you want to keep the original look.
econo racer
Post by econo racer » Sat May 11, 2019 3:39 am
Bill I have owned them about 40 yrs. and they mean a lot to me. They were originally black.
408swinger
Post by 408swinger » Sat May 25, 2019 4:02 pm
Have them powder coated.
Racer71
Post by Racer71 » Sun Jul 07, 2019 2:37 pm
I agree with having them coated they’ll look good for a long time
pitts64
Post by pitts64 » Wed Aug 28, 2019 8:53 am
I've painted a lot of rally wheels and never once had a issue like that.
I've been looking for a set of those wheels for my 69 El Camino, they came from the factory on the 71-72 el camino I think. Cant go wrong with the factory steel wheels, they usually ride smooth as silk and balance up real nice..
I prefer paint, it shows the grain of the steel.
econo racer
Post by econo racer » Thu Aug 29, 2019 5:05 am
My sand blaster tank is a cheapo and it would take to long. There is a guy down the road from me that has a serious blaster. Might check out.
pitts64
Post by pitts64 » Fri Aug 30, 2019 8:58 am
I wanted to try a high pressure washer and then wet sand them. The trouble with sand blasting is the sand gets caught in the grooves of the wheels and nothing can get it out..
