https://www.sensorprod.com/news/white-p ... /index.php
Many other full text automotive/engineering themed papers available at no charge:
https://www.sensorprod.com/research-articles/index.php
Thank you, MadBill.
Conductive Heat Transfer Across a Bolted Automotive Joint and the Influence of Interface Conditioning
- BigBlockMopar
- Momentary Specialist
Re: Conductive Heat Transfer Across a Bolted Automotive Joint and the Influence of Interface Conditioning
Interesting stuff.
How about this Bolt-pressure sensor?
https://www.sensorprod.com/tactilus/bol ... icator.php
(I could think with angle milled heads for instance)
Bolted joints are an insane rabbit hole that can take over your life if you get into the hardcore engineering of it.
We've got a team of people who ONLY do bolted joint analysis, the information form we have to fill out and submit to have our setup analyzed makes you realize there's things you would never consider in the design. It's insane. It also makes you realize that many companies, even ones you might consider high quality, get it very wrong. Tough stuff.
I totally agree- Though I'm not a ME, I've had experience with OEMs stating that the proper amount of torque applied to a fastened joint was measured by the flattening of the lock washer fitted on the nut side. I showed them it could take as little as 7 ft/lbs on a 3/4" fastener to flatten the lock washer...crickets ensued.LoganD wrote: ↑Wed Jan 22, 2020 9:26 am Bolted joints are an insane rabbit hole that can take over your life if you get into the hardcore engineering of it.
They might have been confusing Belleview washers with simple lock washers. Might not have taken good notes that day in class.
Bolts in bending - bad.LoganD wrote: ↑Wed Jan 22, 2020 9:26 am Bolted joints are an insane rabbit hole that can take over your life if you get into the hardcore engineering of it.
Bolts in single shear - ok.
Bolts in double shear - better.
Bolted joints designed to use local stiffness to carry the load while the bolt just applies clamp - more better.
Sometimes applying more bolts or 12.9's doesn't necessarily make the joint better.
The best designed bolted joints can be easily defeated by manufacturing's selection of a torque tool.
One of the most accurate torque tools is a skilled person's sense of feel during the process.
