Ram Front End
chimpvalet
Ram Front End
Post by chimpvalet »
Hoping for advice on how to check whether the ball joints, etc on the front end of a 2006 Dodge Ram 2500 are good as they should be. Drove my folks' Ram for an hour on the way to my go-to mechanic and thought it wandered a bit much, not all that easy to keep dead on track so asked my guy to look into the front end while there for A/C work. He has not found anything obviously loose and while I have high regard for him and his crew wonder whether anyone here can advise how best to check this out?
Thanks,
Steve
SupStk
Re: Ram Front End
Post by SupStk »
If it's a 4x4, check the track bar for loose bolts, bushings or egg shaped bracket holes. Something else I've seen the front bumper and brackets loosen which can cause the "death wobble".
Monty Frerichs
B&M Machine
