moving front ARB droplinks onto wishbones
sambeeb
Post by sambeeb »
Hi,
My VW Polo gti has its front anti roll bar acted on by long droplinks that come down from strut flanges. I'm going to move away from this system to where short drop links coming off the wishbones will act on the FARB. In the proposed system the droplinks will be coming off the wishbone roughly half way along its length. The current system acts on the bar via the strut. Most Mac strut front ends have a movement ratio of 0.9 so for say 10mm of wheel deflection the spring/strut body will move 9mm. That'll translate to pretty close to 1:1 of wheel:bar movement. The proposed system for that 10mm of wheel movement will probably only move at the bar by half that but to my eyes will have more leverage over the bar too yes? Am I correct in that?
If so, and I'm aiming to retain the same roll resistance from the FARB, under the new system I would theoretically have to move to a stiffer bar yes??
sam
Re: moving front ARB droplinks onto wishbones
Connecting at the midpoint of the wishbone will give a motion ratio of 0.5:1, so the bar would have to be almost twice as stiff to have the same effect.
dannobee
Post by dannobee »
Not to pick nits, but the equation is the motion ratio squared. (9/10)^2= 0.81 If the point is changed to halfway, (5/10)^2 = 0.25
The bar will need to be over 3 times stiffer. This can be accomplished by running a stiffer bar or moving the other end of the link closer to torsional center of the bar (i.e. shorter "arm length" of the sway bar). Or both. He'll need to do the math on the bar if he wants it to handle the same as before.
I'm sure there are online calculators out there for computing bar stiffness. Compare the before and after stiffness for each scenario.
If you're familiar with Excel or something similar, make a page with the inputs and make one function cell to spit out the answer.
Since aftermarket bars often have multiple holes (or slots) drilled in the arm ends, or have a bar clamp end allowing infinite adjustments within the range, it's something you should compute and jot down in your notebook for future reference.
I knew that. Even built adjustable attachment points for my Camaro with a long link and a number of mounting points along the wishbones.:oops: :oops:
sambeeb
Post by sambeeb »
thanks guys. As a follow up I was aided by a race engineer in what the effects would be. Packaging constraints meant that I was going to need to attach the droplink onto the wishbone roughly in their middle. ie the midpoint of the ball joint and the inner lower control arm bush was just a touch outside of the anti roll bar. He said that placing the droplink there would de rate whatever bar I ran by 75%.
The car in stock form had come with a 20mm bar that was too soft. An upgraded 22mm bar on its hard setting (with the links in the strut mounted position) was spot on. I really had confidence in the front end like that on 7kg/mm springs. In whitelines charts, this bar was 75% stiffer than the stock one.
By consulting this table https://www.whiteline.com.au/docs/bulle ... BL-281.pdf it turned out that if I ran a 24mm bar on hard (roughly 70% stiffer than the 22mm bar had been) it would then de-rate by roughly the same amount (75%) due to the new droplink position, bringing the end anti roll back to where I'd previously liked it with the 22mm bar.
I went ahead and made my droplink pickups, had them welded, made up some droplinks and fitted it all up. Its easier if you look on my current build thread for the pics and review. But I can recommend it, the front end is another step up now because of it, I can recommend it for street and comp and I'd honestly hate to go back.
starts pretty much here but discussions with the race engineer were earlier https://www.vwwatercooled.com.au/forums ... 62-10.html
