Titanium Rotors
chimpvalet
Titanium Rotors
Post by chimpvalet »
Just learned titanium rotors are on the market, this thread commenced in hope of characteristics observed in service.
Cheers
Steve
lefty o
Re: Titanium Rotors
Post by lefty o »
entirely titanium, or 2 piece units with a titanium hat?
Racer71
Re: Titanium Rotors
Post by Racer71 »
I’ve used them on our dirt midget, lightweight they brake decent when the coating wears off it’s either get them recoated or replace them-$$$, take a specific compound pad as well which are also a touch high. We use thin solid rotor and the weight is amazing. Not sure if you’re looking at vented ones with a hat etc. red devil are the ones we use.
chimpvalet
Re: Titanium Rotors
A buddy collaborating on custom upgrade for a rather light street sportscar brought this to my attention today. What's in view are 12" solid rotors for hat mounting, curb weight of the cars about 2200 lb. I'm skeptical as to the suitability for this but gotta keep an open mind where technology leads us.
FC-Pilot
Re: Titanium Rotors
Post by FC-Pilot »
With titanium rotors you either need to have them coated or use specific pad compounds. Being that they don’t dissipate the heat away it has a big impact on how it affects the pads.
Paul
j-c-c
Re: Titanium Rotors
Post by j-c-c »
Yes, you are correct about that they operate at a higher temp, and pads/fluids selected need to be up to the task, but pads are cheaper then the rotor, and the weight savings is significant over iron, and with higher temp delta, cooling ducts are that much more effective. Basically same as CF rotors but 1/3? the cost and 1/3? more weight, dead, unsprung, and rotational?
agertz1
Re: Titanium Rotors
Post by agertz1 »
I suspect you can by Al. Sic. ceramic plate and water-jet to size. Buy current, on the market ceramic rotors ? Sprint cars have used aluminum rear rotor, for years. Not for road racing ! I'm building an 800 lb. reverse trike,(3 seater). It's using 14.5" x .37" thk. alum. rotors in front. (1) 15" in back. All bolted to wheels at outside dia.,( calipers on inside diameter, like Buell/etc). Wilwood pads and hardware. Make inside, 2 piston calipers.
Good Luck, Art.
