Rear End Parts
liqu
Rear End Parts
Post by liqu »
Hi Guys I'm stuck, I have a 234" Spitzer rear engine dragster, one of my rear axle studs came loose and cut a groove in the caliper bracket, so I went to buy a new stud and bracket, I can't find them anywhere, the bracket is made by JFZ, the stud is 4" long with a 1 1/2 journal 1 1/4 treads on one side and 1 1/8 on the other 5/8 x 18 TPI, I know I can replace it all and I may have to, I would rather just replace the bad parts, This is Spitzer housing with Strange axles and 3rd member (9" Ford), Any Ideas?
miniv8
Re: Rear End Parts
Post by miniv8 »
The Mark Williams bracket looks just like that, except for your two holes that have no torque signs.
Might give them a call for dimensions
liqu
Re: Rear End Parts
Post by liqu »
Yes I did, just enough to not work, I may try welding the one I have.
