Nova or camero rear shock mount?
econo racer
Post by econo racer »
Do :? the original staggered shock mounts work better than welding a cross bar and mounting both shocks behind the rear some what angled?
dannobee
Re: Nova or camero rear shock mount?
Post by dannobee »
Yes. Wheel hop was a problem on the first Camaros. The GM engineers fixed it by staggering the shocks by '68.
There's some math involved if you want to do it right, as the moment arm depends on how far the lower shock mount is away from the axle tube (in side view) as the pinion yoke rises under acceleration. From the rear view, the angle of the shocks at the top determines the motion ratio and effectiveness of the shock and spring. As the angle moves away from vertical, the effectiveness of the shock and spring decrease, but packaging becomes more difficult.
econo racer
Where are the shocks mounted on a stock class Nova?
dannobee
Post by dannobee »
Stock Eliminator car? AFAIK, the upper mounts must be in the factory location but the lower mounts can be mounted to the traction bar.
discloseenjoin
Post by discloseenjoin »
dannobee wrote: Tue Mar 08, 2022 10:21 am Stock Eliminator car? AFAIK, the upper mounts must be in the factory location but the lower mounts can be mounted to the traction bar. basket random
Incompatibility between the two connectors has the potential to reduce efficiency.
