TRE Racing completely distroyed by Fire.
TRE Racing was completely destroyed by a fire recently. This is a good time for everyone to review their fire suppression procedures for your shop/garage.
http://www.dragzine.com/news/taylor-las ... ight-fire/
Joe Facciano
Re: TRE Racing completely distroyed by Fire.
& my engine was melted to the ground.
Hope all goes well for Taylor, probably be next year for my new engine...
'69 Camaro-N/A-23°-SBC-2988#
Best 1/8 mile pass 5.753 @ 119.92
http://www.dragzine.com/news/homebuilt- ... -1969-z28/
Wow I hope all his customers have documentation that their parts/engines are there.I know sometimes I drop off things at a shop and paperwork is not immediately generated especiallyl if you are a daily /weekly customer !
I made a deposit with my credit card, so that should cover me.
I wonder if they were storing gasoline in the building ???
Read on Facebook , they were dynoing an engine when the flywheel came apart and cut the fuel lines,starting the fire.
The more I know,the harder it gets.
A dyno should have fire suppression, manually operated and perhaps automatic CO2, and Purple K or Monnex hand extinguishers. Sand for magnesium.
I've seen Flywheel and Flexplate fly apart before.
Are running the fuel lines in that way typical? Why wasn't some sort of shield being used?
It often passes through my mind that younger performance enthusiasts are more exposed to engines with flywheels/clutches that will survive much higher rpm excursions without a problem. They might not have heard of or experienced this type of explosion.Lizardracing wrote: ↑Mon Feb 29, 2016 1:04 pm I've seen Flywheel and Flexplate fly apart before.
Dry powder chemical extinguishers do work with mag but, it becomes a real mess. Not as messy as the fire continuing, though.
Is this the tre racing that does a lot of online sales?
http://www.treracingengines.com/treabout.shtmlBill Chase wrote: ↑Thu May 28, 2020 10:55 am Is this the tre racing that does a lot of online sales?
