Forum change
Open
GLHS60
Forum change
Post by GLHS60 » Mon Jul 17, 2017 6:21 pm
There used to be a little "squiggly" icon at the top right of the page to change the size of the print.
I believe there were 3 different sizes available.
I can't find it anymore, is it somewhere else or has it been deleted.
My old eyes need larger print!!
Thanks
Randy
Sherwood Park
Alberta,Canada
jred
Re: Forum change
Post by jred » Mon Jul 17, 2017 11:18 pm
I use ctrl + for bigger and ctrl- for smaller works on my laptop,, try it :mrgreen: :mrgreen:
In-Tech
Re: Forum change
Post by In-Tech » Tue Jul 18, 2017 12:43 am
jred wrote:I use ctrl + for bigger and ctrl- for smaller works on my laptop,, try it :mrgreen: :mrgreen:
Now that's cool. =D> It took me a bit to find the + button without my glasses though :mrgreen:
-Carl
GLHS60
Re: Forum change
Post by GLHS60 » Tue Aug 01, 2017 2:31 am
Appreciate the input!
Thanks
Randy
Sherwood Park
Alberta,Canada
midnightbluS10
Re: Forum change
Post by midnightbluS10 » Tue Oct 10, 2017 3:41 am
I could have sworn there was a thread about the latest forum update but I can't find it.
Just noticing some things about this update. For example....On Android devices, when posting a pic or link or bold words or italics or anything that requires you to use the "buttons" above the reply box, when you tap the tag you want it only adds the tags to the screen, which makes it difficult to post pictures(or whatever else) because now you have to try to tap on the single spot in between Image and then have to finish the tags. That takes a lot more. Time and adds a lot of aggravation.
Or you can paste whatever you need tags around, select it, then add tags with the buttons above the reply box, which also takes more time and causes more irritation. It's not easy to do precision selecting on these things lol.
When you go to forums like Yellowbullet, for example, and try to post pictures, links, etc...it's a much easier process. When you click the img tag, a box pops up that you paste your link(or words) into and it adds the entire link with tags to the reply box. Meaning I don't have to try and click that tiny spot, paste, retype tags, and then post.
Is there a way we can have that here? Where a box pops up to paste your stuff into when you use tags? Was it like that before? I don't remember having to always do this but I could be wrong.
Thanks.
JC - Precision Guesswork & Expert Up Arrow Manipulation
exhaustgases
Re: Forum change
Post by exhaustgases » Mon Nov 26, 2018 8:57 pm
I would like to see the "My posts" deal come back so you can look at all the threads you posted in. And even nicer would be a date function and to jump to the post. Hey this is a computer age and all those things are possible.
