Iskenderian Mile A More Camshaft ID help
Agave
Post by Agave » Tue May 19, 2015 7:53 pm
I've got this camshaft with these ID #'s :
Y75V
3380S0
5P
201_96M
Can anyone help with a cam card or specs for this?
Thanx
Re: Iskenderian Mile A More Camshaft ID help
Post by pdq67 » Sat Jun 27, 2015 11:46 pm
This is an old thread, but I don't think Isky gave out spec's for them. Probably have to mock it up and install a degree wheel to find out.
Geoff2
Post by Geoff2 » Tue Nov 10, 2015 7:11 pm
Mile -or -Mor cam
I could not find that particular part # in my old Isky catalog, but all the MOM cams listed had 248° adv duration & 0.400" valve lift with 1.5 rockers. LSA was not given.
Post by pdq67 » Tue Feb 16, 2016 3:13 pm
Here is one for an AMC engine but I figure they all are pretty-much the same.
Part Type:Camshafts
Product Line:Isky Hydraulic Flat Tappet Camshafts
Summit Racing Part Number:ISK-1331-M
Isky Grind Number: Mile-A-More
Camshaft Manufacturers Description: For use with lower compression ratio engines.
Basic Operating RPM Range:1,000-3,800
Cam Style: Hydraulic flat tappet
Valve Springs Required: Yes
Advertised Intake and Exhaust Duration: 248
Intake and Exhaust Duration at 050 inch Lift:194
Lobe Separation (degrees):108
Intake Valve Lift and Exhaust Valve Lift with Factory Rocker Arm Ratio:0.425 in.
Computer-Controlled Compatible: No
If I remember right it was on 108/104 or something like this???
And they made two different versions, this one and one a schosh bigger for the bigger engines???
Hope this helps? I haven't heard of these cams in years and years!!
