Engine Masters 2019
Mummert
Re: Engine Masters 2019
Post by Mummert » Thu Jul 18, 2019 11:32 pm
Found some 15* tulip LS exhaust valves from ferrea so that is a step forward for me.
Mummert Y-blocks
Carroll
Post by Carroll » Sat Jul 20, 2019 4:46 pm
Anyone building a SB Chevy for early iron this year. JC
Walter R. Malik
Post by Walter R. Malik » Sat Jul 20, 2019 7:56 pm
Yep ... Adney Brown has entered with a 327/275 from 1966.
461X heads certainly have some thick walls.
Ted
Post by Ted » Sat Jul 27, 2019 9:19 am
No secrets on our end. Joe Craine and I are slowly getting parts together for our Y-Block entry. It is based off of a 292 and not a 312. The 312 main sizing has been a proven detriment in making power so the smaller mained 292 it is. Finding a good pair cylinder heads has been challenging. I've lost track how many oem cylinder heads have hit the scrap iron pile at this point simply due to them being either used up, cracked, or simply too thin to port heavily. I started this project with a healthy stack of 'G' and '113' heads and that has dwindled down to essentially nothing. Joe has been working over those heads that have been usable and we now have at least three decent pair to work off of. We did take advantage of the discount offered by JE Pistons for EMC participants. Every little bit helps at this point. Ted Eaton.
Ted Eaton
czar racing
Post by czar racing » Mon Jul 29, 2019 4:52 am
I am also entering a 327 SBC this year.
Chris
Carroll
Post by Carroll » Mon Jul 29, 2019 5:42 am
How’s the engine coming along Chris. I always like to see the little motors do well. JC
czar racing
Post by czar racing » Sun Aug 04, 2019 11:18 am
Well, it seems like it is moving along better this year than in previous years. I have most of my parts in and my cylinder heads are sorted out. I had some issues with my 1st block and had to chase down a replacement. The replacement has more bore than I originally wanted but it will get the job done so ill tack on a few cubic inches.. haha. I should have it together by mid-end of August so I can get it on the dyno. I work full time so I am trying to squeeze it in around my schedule. Fortunately I work at Late Model Engines and have an entire machine shop at my disposal and what we lack I have been able to use the equipment over at SAM Tech to accomplish. I think it should perform well though.
Chris
Mummert
Post by Mummert » Tue Aug 27, 2019 7:32 pm
Its crunch time! Anyone makin' headway out there. I've been battling some things but starting to get though it. Hope to have the engine running in the next couple of days. Hope I'm not the only one who hasn't gotten fired up yet. :|
Mummert Y-blocks
Walter R. Malik
Post by Walter R. Malik » Tue Aug 27, 2019 7:42 pm
If this is gonna be like past contests, contestants seem to wait till after Labor Day to begin running & tuning on their engine; which was mostly assembled weeks before then.
#-o
JonKaase
Post by JonKaase » Tue Aug 27, 2019 9:36 pm
Honed my O So Thin Chevy block tonight. Even at .010 over Std, it is scary thin between 3 cylinders. I am 2 weeks away, have almost all the parts but have to work during the day just like everybody else. Anyone else running?
Walter R. Malik
Post by Walter R. Malik » Wed Aug 28, 2019 10:05 am
Adney's engine is completely ready to run but, hasn't yet.
JonKaase
Post by JonKaase » Mon Sep 02, 2019 6:08 pm
Finished pistons/ compression today and got the shortblock together. A little headwork and should be ready end of this week.
JonKaase
Post by JonKaase » Mon Sep 02, 2019 6:12 pm
Won’t need much testing this year. No extra parts and nothing to try. Just get the jets right and the timing
Walter R. Malik
Post by Walter R. Malik » Mon Sep 02, 2019 8:37 pm
There's a whole lot of intake manifolds for a big block Chevy, many carb spacers and headers, too.
Depends upon how much time and money you wish to outlay in order to flog it all.
You are being like the rest of us now ... picking an end combination and tuning that combination as best you can [-o<
Mummert
Post by Mummert » Tue Sep 03, 2019 4:21 am
I have a couple pieces to try that friends lent me, but nothing like the big dreams I had at the start of this deal. The time spent on the little things can sure make the days go by.
Mummert Y-blocks
