Engine Masters 2019
Gregory
Re: Engine Masters 2019
Post by Gregory » Fri Apr 19, 2019 7:01 pm
If you didn’t make the cut for the EMC you’re welcome to come play at the REC.
We had a competitor that had issues and had to drop out.
We will run the dyno to match the EMC rules so you can see how you would have matched up.
If nothing else, you’ll have a good time also attending our on site tech seminars.
All contact information is on the web site.
www.RaceEngineChallenge.com
Olds455
Post by Olds455 » Sun Apr 21, 2019 8:35 am
Did you really just do that? No shame, huh?
gmrocket
Post by gmrocket » Sun Apr 21, 2019 1:45 pm
Ya he did...whats the problem?
If you didn't make the EMC, why not take him up on his offer and bring your engine to the REC and run it under the EMC pull guidelines ...where is there shame in that?
Last year I was accepted in the EMC, started my build, could not get any answers to questions from the EMC,, through June and July,, it's like they dropped off the face of the earth. Others had the same problems,, I couldn't move forward without answers.
So I jumped into the REC....no drama whatsoever
Walter R. Malik
Post by Walter R. Malik » Sun Apr 21, 2019 8:15 pm
This year, that the two contests are run in different weeks, one can visit both as someone's team member, whether a contestant or not
gmrocket
Post by gmrocket » Wed Apr 24, 2019 12:06 am
Is there an official list out yet?
Ted
Post by Ted » Wed Apr 24, 2019 8:42 am
Just to let everyone know, the Eaton Balancing entry has been approved for this years EMC. Joe Craine and I are teaming up together and we will be entering a Ford Y-Block as the engine of choice. We had some other options but the Y still looks like a contender even with iron heads being used. That being said, this year will be more of a challenge with the iron heads being used instead of the aluminum heads we've used in the past. It would be nice to know at this point who has been accepted and what the variety of engines are going to be in the 'Early Iron' class. Ted Eaton.
Ted Eaton
Walter R. Malik
Post by Walter R. Malik » Wed Apr 24, 2019 2:37 pm
I can say that I have started work for others on things for three different engines; a 327 Chevy, A 429 Ford and a Big block Chevrolet.
Mummert
Post by Mummert » Wed Apr 24, 2019 5:58 pm
After speaking with Adger, we had to make an application adjustment. He said I'm approved and will be getting an official email in a week or so.
Mummert Y-blocks
gmrocket
Post by gmrocket » Fri Apr 26, 2019 10:31 am
anyone know if there is an alternate list?
JonKaase
Post by JonKaase » Tue Apr 30, 2019 9:42 pm
So who’s in and what are they running?
RAMM
Post by RAMM » Tue Apr 30, 2019 9:44 pm
Chrysler 413. J.Rob
New and improved website under construction.Check the blog for relevant info
http://skmfxengines.blogspot.com/
Barry_R
Post by Barry_R » Thu May 02, 2019 12:40 pm
In with the 410 Mercury
Need to get a set of "Mercury" valve covers...
Survival Motorsports
www.survivalmotorsports.com
WD for Comp, Manley, Blue Thunder, Diamond
Probe, Holley, Clevite, Federal-Mogul, Scat....
Walter R. Malik
Post by Walter R. Malik » Fri May 10, 2019 12:17 pm
Just really curious ... has anybody gotten a listing of all those competing in the Engine Masters Challenge this year...?
JonKaase
Post by JonKaase » Fri May 10, 2019 6:21 pm
I know of:
Mummert with a 289 ford
Ted Eaton and Joe Clark with a 312 ford Y-block
Barry Robotnik, 410 FE
Ramm, 413 Chrysler
me with a 427 Chevy
What else Randy? No list will be sent out I hear
Walter R. Malik
Post by Walter R. Malik » Fri May 10, 2019 8:58 pm
I know of:
Ramm, 413 Chrysler
me with a 427 Chevy
I know of three more but, that's all:
Adney Brown = 327 Chevy
Buck Hincle = 396 Chevy
Daniel Boshears = 429 Ford
