01 Mustang GT bullet clutch kit
mitch
Post by mitch »
Got a customer that brought me a 6-01 mustang gt bullet. I pulled the clutch because the fork was rattling around and customer said clutch was replaced at ford not long ago... long story short when I got the clutch out it has a 11 inch disc and the inner measurement on the disc is 6.5 inches and the flywheel inner machined surface is 7 inches so when the disc wears it has 1/4 inch surface not wearing on the flywheel side but is right on the pressure plate side.Does anyone know what kit and flywheel that I need to get both surfaces the same . I got a kit from parts house and a new flywheel and it is the same way (6 bolt). I got a 10.5 kit that the inner diameter is 7 inches but the pressure plate will not mount to flywheel.
Thanks in advance
Mitch
mitch
Re: 01 Mustang GT bullet clutch kit
Post by mitch »
Found what i needed
Thanks
Racer71
Post by Racer71 »
Spec clutches has always done us well on mustang stuff.
