1990 chevy 1500 No Tail lights.
My 90 model chevy 1500 has no tail lights. Did not when I bought it.so never leaves the yard. Has a burnt valve at 301K. Brake pedal hard. Might be from bad vacuum from the valve. But here is where I get lost. Has 2 complete new tail light assemblies. No brake lights. no backup lights, No tail lights period. So I check for voltage back there. Nothing. All fuses good. I am not putting a new motor in until this is fixed 1st. Whats a man to do
Re: 1990 chevy 1500 No Tail lights.
Get a service manual with a wiring diagram and figure it out ???
- New Member
BBB industries has a lot of free wiring diagrams and tsbs you can sign up for a free account
Most trucks have a harness at the rear that plugs into a harness that runs from the front to the back. Check for where the harness plugs in at the rear. Unplug it and test again for power at the connector. Could be unplugged, could have bad connection, could be unplugged further up front. I'm not familiar with that year, but my old '06 1500 had a problem at the rear connector.
Jeff
Jeff
As soon as I get a free rack that is where the problem could be. Some hack has been in there Thanks Shark.
Any time I see a pickup with rear lighting issues, I can trace it to where someone used "vampire taps" to add trailer wiring, and the wiring has corroded all to hell.
It's also usually in a giant wad of electrical tape, which mostly serves to collect and store moisture for faster wire destruction.
Exactly! This is unfortunately very common on pickups. Corroded bulb sockets is also common.peejay wrote: ↑Sat Sep 21, 2019 9:18 am Any time I see a pickup with rear lighting issues, I can trace it to where someone used "vampire taps" to add trailer wiring, and the wiring has corroded all to hell.
I have had them fail due to the shitty design with the truck never being touched.travis wrote: ↑Wed Sep 25, 2019 4:48 pmExactly! This is unfortunately very common on pickups. Corroded bulb sockets is also common.peejay wrote: ↑Sat Sep 21, 2019 9:18 am Any time I see a pickup with rear lighting issues, I can trace it to where someone used "vampire taps" to add trailer wiring, and the wiring has corroded all to hell.
Obviously it is fuse or wiring related... Should be obvious if tested... It's just a path, follow it and see where it stops.econo racer wrote: ↑Fri Sep 20, 2019 6:42 am My 90 model chevy 1500 has no tail lights. Did not when I bought it.so never leaves the yard. Has a burnt valve at 301K. Brake pedal hard. Might be from bad vacuum from the valve. But here is where I get lost. Has 2 complete new tail light assemblies. No brake lights. no backup lights, No tail lights period. So I check for voltage back there. Nothing. All fuses good. I am not putting a new motor in until this is fixed 1st. Whats a man to do
most of the time its bad trailer wiring causing the problem
