1987 Allegro drivetrain worth?
n2xlr8n
Post by n2xlr8n »
My used-to-be pristine 87 Allegro with ~35k miles is beyond my time to restore it.
It is commonly understood that to remove the GM 454, it will have to come out of the cab. Labor-intensive, to say the least.
I'm trying to decide if a 35k mile, standard bore 454 (and HD TH400) is worth the effort- I have nothing to put it in, or no plans to build a 496, etc.
Thoughts?
SupStk
Re: 1987 Allegro drivetrain worth?
Post by SupStk »
Most GM based motorhomes can be more easily serviced by dropping the engine out the bottom. I used a truck transmission jack to remove the suspension crossmember (it unbolts from the frame). Then using the same jack with a fixture, remove the engine and transmission as one unit.
Monty Frerichs
B&M Machine
n2xlr8n
Post by n2xlr8n »
SupStk wrote: Sat Feb 29, 2020 8:41 am Most GM based motorhomes can be more easily serviced by dropping the engine out the bottom. I used a truck transmission jack to remove the suspension crossmember (it unbolts from the frame). Then using the same jack with a fixture, remove the engine and transmission as one unit.
Thank you very much- I had heard that, but it was from a source I wasn't sure about.
rfoll
Post by rfoll »
The transmissions in some of the trucks, busses, and motor homes had special gear sets and are highly sought after. Substantial gear whine in first and second tells the story.
