positive locking fastener
Re: positive locking fastener
I couldn't find any Junker tests on it. Do you know how they compare to Nordlock or Schnoor washers?
Here is the NAS 3350:
http://integra.cimav.edu.mx/intranet/da ... UALITY.pdf
Here is a video of Schnorr washers failing a Junkers test:
Here is a video of the Nord-Lock passing a Junkers test:
I have the sense that if the Nord-Lock would also pass the NAS 3350 that it would be front and center in their advertising.
https://www.machineryanalysis.org/post/ ... ns-9673590
Could very well be that they'd advertise it if it did.
In heavy rail, we now use the Nord-Locks almost exclusively. In the high vibration areas (like wheel caps) it's Nord-Locks AND safety wire.
We've been using nordlock washers on our stamping presses at the shop for about 20 months, cuts out the weekly torque checks, just by switching we've been able to go to a monthly torque check. And some of these bolts are over 300 ft lbs.. they work great, tried to get the boss to go to safety wires so we could just do visual inspections quickly. They don't want to spend the money just yet..
Neat idea. Seems like it would prevent unlimited backoff but there would have to be some loose motion for the spring clutch concept to work on the threaded diameter. Also would the male thread become damaged and one-use? Is precision sizing of a socket wrench required? Not criticism, just observations.
I wonder if one could have precision bolts with an unthreaded tip that the spring could immediately grip?
Dave
We use "torque stripe" (aka Dykem Cross Check) as a visual reference for any movement of the fastener. Since we're a quasi governmental agency, the manufacturer depends on the lowest bid contract, but Dykem is common.Bill Chase wrote: ↑Tue Jun 02, 2020 5:32 am We've been using nordlock washers on our stamping presses at the shop for about 20 months, cuts out the weekly torque checks, just by switching we've been able to go to a monthly torque check. And some of these bolts are over 300 ft lbs.. they work great, tried to get the boss to go to safety wires so we could just do visual inspections quickly. They don't want to spend the money just yet..
Interesting – so, how freely available are these KATO LockOnes (where, how much)?
My vibrations just consist of going over rutted dirt roads, but it was enough to unscrew my six M6 bolts holding my skid pan, but being of a heavier metal to protect my oil pan, we call it a bash plate. Nordic Lock (Nord-Lock Wedge / Delta Protekt Heico-Lock) washers were sufficient to keep them in place where lock washers couldn't.
Finally stripped the M6s pulling the heavy bash plate up to the body and replaced (drilled and tapped) the two front ones with high-tensile M8 bolts and the four back ones with M10. Problem solved.
Cape Town, South Africa
It is probably easiest for you to trade through the UK:
https://www.incora.com/
[ https://www.wescoair.com/contact-us/locations ]
UNITED KINGDOM
SCOTLAND
ABERDEEN
Unit 4, Robert Leonard Industrial Estate, Howe Moss Drive (Hub)
Aberdeen AB21 0BG, United Kingdom
+44 1224 773 100
EMEAenquiries@wescoair.com
WEST SUSSEX
CRAWLEY
2 Kelvin Lane, Newton Road (Hub)
Crawley RH10 9TY, United Kingdom
+44 1293 459 500
WEST YORKSHIRE
CLECKHEATON
Lawrence House, Riverside Drive
Cleckheaton BD19 4DH, United Kingdom
+44 1274 024 601
UKSales@wescoair.com
HUDDERSFIELD
Park Mill Way
Huddersfield HD8 9XJ, United Kingdom
+44 1484 867 701
https://www.adeptfasteners.com/
International Sales
Director of Global Business Development
Mark Johnson
PH: 44 7880 722 980
mjohnson@adeptfasteners.com
UNITED KINGDOM
SCOTLAND
ABERDEEN
+44 1224 773 100
WEST SUSSEX
CRAWLEY
+44 1293 459 500
WEST YORKSHIRE
CLECKHEATON
+44 1274 024 601
HUDDERSFIELD
Park Mill Way
+44 1484 867 701
International Sales
Mark Johnson
PH: 44 7880 722 980
Dust Buster wrote: ↑Sun Jun 07, 2020 11:45 am Interesting – so, how freely available are these KATO LockOnes (where, how much)?
