A/C Service Ports
chimpvalet
A/C Service Ports
Post by chimpvalet »
Finalizing a scratch-built A/C system for my project car, asking for advice on where to place the service ports. Are there specific do's and don't's?
6.50camaro
Re: A/C Service Ports
Post by 6.50camaro »
Personally ,I would but the low side port either on the accumulator or just before it on the evaporator coil side . So when charging as a liquid any liquid left after it flashes to a saturated vapor will be held in the accumulator and not flood the compressor with liquid . On the high side any where between the condenser coil and the evap. coil is good as long as its before the metering devices . That way if you have to take the refrigerant out you can pull it as mostly liquid and pump it down faster . just my view on it . Dan
