GRADE 2 Titanium bolt Strength
BOOT
Post by BOOT »
Ok been trying to figure out a comparison and the info I find is conflicting. Some say grade 2 titanium is weaker than steel grade 2 and others say it's comparable to steel grade 5
I want to change from a Steel grade 5 bolt to the next size up Titanium grade 2, by my calc bout a 31% weight reduction because of the next larger size. It's a pull load so not worried bout shear
Racer71
Re: GRADE 2 Titanium bolt Strength
Post by Racer71 »
What’s the application? We use them all over the dirt midget and never have failure, even in certain places like shock bolts where we used to use 1/2-20 and have went titanium and down to 3/8 size by changing eyelet in the shock. Smith titanium and ti-22 as well Astro are all good to deal with.
BOOT
Post by BOOT »
Yah I wouldn't hesitate to downgrade size in many spots. I don't wanna go into detail atm for a couple reasons. But it's actually more like 2 sizes larger bolt as it's common to upgrade it one size from stock, since the stock size sometimes breaks.
Rick!
Post by Rick! »
It appears Grade 5 Ti 6al-4v is what you might want to consider.
It has a strength similar to a Class 10.9 but its stretch will be considerably more due to a much lower Young’s modulus (E) as compared to steel.
https://material-properties.org/what-ar ... efinition/
Racer71
Post by Racer71 »
Gotcha on application. We use them fir the radius rods shocks headlocks and wheel centers brake rotor to hat and torsion bar hardware jacobs ladder and I’ve yet to see a failure on any that wasn’t caused by a crash. We buy them at a local open wheel specialty shop. He sticks them in bulk in the common sizes and as well as some packaged specialty stuff.
BOOT
Post by BOOT »
Rick! wrote: Sat Mar 27, 2021 8:21 am It appears Grade 5 Ti 6al-4v is what you might want to consider.
I agree Ti64 would be more ideal BUT...
j-c-c
Post by j-c-c »
I can't see personally use of Grade 2 Ti on a race car in any application that failure would cause an accident. Even Ti Grade 5 IMO should be used thoughtfully, as Ti is reported to be between Alum and Steel on its fatigue limits.
BOOT
Post by BOOT »
j-c-c wrote: Sun Mar 28, 2021 12:38 am I can't see personally use of Grade 2 Ti on a race car in any application that failure would cause an accident. Even Ti Grade 5 IMO should be used thoughtfully, as Ti is reported to be between Alum and Steel on its fatigue limits.
Got any data to say why? Unless I find tensile strength of the exact Ti grade 2 bolt like I can for steel...
BOOT
Post by BOOT »
Was just trying to look into Ti bolts more and found Cadmium plating causes embrittlement with Titanium, also silver but that's much less likely to happen than a cadmium plated nut/washer/bushing/bracket used with Ti hardware
Rick!
Post by Rick! »
Grade 5 Ti is corrosion resistant without plating. (ref link above). Electro plating a Gr 5 Ti bolt doesn’t pass the “good quality screw” sniff test. Mechanical plating like zinc flake or the use of electroless nickel are better options.
What’s your projected weight savings with Ti hardware?
BOOT
Post by BOOT »
Titanium is corrosive resistant in general from what I've read.
The embrittlement from Cadmium plating I mentioned was like if using a Ti bolt with say a steel cadmium plated nut
Weight savings are savings if your willing to put the time and money into them. Other means and materials are often cheaper but in this case it's steel or Ti
j-c-c
Post by j-c-c »
BOOT wrote: Sun Mar 28, 2021 12:55 pm
Why what? The seriousness of a bolt failure in a race car in a suspension application, the difference in properties of Ti in grades 2 and 5 , or the relative fatigue limits of Ti being between Steel and Alum?
BOOT
Post by BOOT »
The one your not being a smarta$$ about
j-c-c
Post by j-c-c »
BOOT wrote: Mon Mar 29, 2021 12:16 am The one your not being a smarta$$ about
Sorry, if I asked to to explain yourself, My bad.
Rick!
Post by Rick! »
BOOT wrote: Sun Mar 28, 2021 9:00 pm Titanium is corrosive resistant in general from what I've read.
That’s not how hydrogen embrittlement works.
If you research titanium bolt hydrogen embrittlement, you should find a reasonable study by hynickelalloy.com. Hydrogen is “installed” during manufacturing and or electroplating processes, not from rubbing a Cad plated nut on it.
