Aluminum Intake Repair
HS Nova
Post by HS Nova »
Attached are a couple of pictures showing damage to the intake runners. I really want to run this vintage intake manifold. The pictures make the gouge look deeper. I would say damage in about a 16th inch deep. Is this even a issue if there is a small leak in the area between ports?
Please help in suggestions to make repair.
Thank in advance. HS Nova
miniv8
Re: Aluminum Intake Repair
Post by miniv8 »
File the edges to make sure nothing breaks off.
Put a dab of silicone there with the gasket, the silicone might or might not be there next time, not that big of a deal really.
Personally I'd just weld it and file it down, but I am privileged in that way.
HS Nova
Post by HS Nova »
I don't even want to know what I'll get charged for the one tack weld I need.
Bumps440
Post by Bumps440 »
I would try epoxy, use a good epoxy and when cured file or shape it smooth.
fordified
Post by fordified »
HS Nova wrote: Sat Apr 03, 2021 2:25 am I don't even want to know what I'll get charged for the one tack weld I need.
That would take about 3 minutes to weld including turning on the machine, grinding the tungsten, turning on the bottle, putting on a helmet and gloves, etc. It's nothing any decent welder couldn't fix in minutes without charging a $100 minimum.
If you're going to surface the manifold, a good shop would also be able to heliarc it. If you're not going to surface it, use epoxy and a straight file to make it smooth with the flange. Put it on and don't worry about it.
HS Nova
Post by HS Nova »
what epoxy would you all recommend?
Bumps440
Post by Bumps440 »
I would use Marine Tex. I have used it for years. There are other good epoxies, but my experience is with Marine Tex.
HS Nova
Post by HS Nova »
Bumps440 wrote: Wed Apr 07, 2021 7:05 pm I would use Marine Tex. I have used it for years. There are other good epoxies, but my experience is with Marine Tex.
Thank you Mr. Bumps and all that responded.
1972ho
Post by 1972ho »
Hey just stick a piece of JB weld in there and sand are file true.
Post by MadBill »
Ignore it, it will have zero effect on the engine's operation. It's not like it can leak to atmosphere; it will just create an immeasurably small back-and-forth flow between the two runners, depending on which cylinder is on its intake stroke.
