Nitrogen not Co2 for Air Shifter & Throttle Stop
BirdMan
Post by BirdMan »
Can Nitrogen be used to replace Co2 for Drag Race Cars? Cost differences, etc. I already am using nitrogen in slicks and have a 20lb?? bottle in race trailer.
Dale C.
miniv8
Re: Nitrogen not Co2 for Air Shifter & Throttle Stop
Post by miniv8 »
Paintball CO2 Tanks
Pros
Low cost.
Weather will impact your accuracy.
Widely available in the market.
Refills are widely available.
Cons
Need to empty a tank before refilling.
Less shots per fill.
Performance fluctuates, especially in hot weather.
Paintball HPA/Nitrogen Tanks
Pros
Performance is stable.
Can be refilled at any point.
More efficient (more shots per fill).
Usually lighter.
Cons
Less available refills.
More expensive.
https://paintballic.com/nitrogen-tanks- ... ball-guns/
dannobee
Post by dannobee »
Another option is buying an old high pressure scuba tank (3500psi) and trans fill your little bottle with plain old compressed air that you buy for $10 for 120 cu ft (or whenever you notice that the little bottle won't quite get up to pressure).
