carb to 68 cowl hood
DCal
Post by DCal »
Can I get a 2" spacer on a SBC with an Air Gap and a drop base GM air cleaner in a 68 Camaro with a stock cowl hood? I don't want to waste dyno time if possible and I don't know what to tell carb guy. Using a holley-type carb. Other than the manifold there must have been a million of these running around
In-Tech
Re: carb to 68 cowl hood
Post by In-Tech »
Incredibly hard question to answer due to many different engine mounts available.
Inside the enclosed .pdf gives an example of how many different motor mounts and heights used.
Shoot just said file too large. Let me see if I can screen shot the Moroso guide.
-Carl
In-Tech
Post by In-Tech »
PART # DESCRIPTION DIMENSIONS (See diagram, right) REPLACES
62500 Chevrolet Motor Mounts A: 1-11/16" B: 2-1/2", .250" zinc plated steel Replaces OEM #3990914
62510 Chevrolet Motor Mounts A: 2-1/8" B: 2-3/8", .188" zinc plated steel Replaces OEM #3962748
62515 Chevrolet Motor Mounts A: 2-9/32" B: 2-3/8", .188" zinc plated steel Replaces OEM #332648*
62530 Chevrolet Motor Mounts A: 1-3/4" B: 2-5/8", .188" zinc plated steel R Replaces OEM #6258154
You can probably download the Moroso catalog. Best I can do for a copy/paste
-Carl
DCal
Post by DCal »
Thanks in-tech. I can see the complexity, the Milodon pan is 8.25 deep and they say to use the tall motor mount but don't give a part number. I will look up the catalog though. I see that you're in NHRA Stocker country so I've probably met you when I was at the races for CP Pistons.
In-Tech
Post by In-Tech »
Yepper, I used to run around with a bunch of scallywags so we probably met somewhere, :lol:
Were you able to download that info? If not, I'll figure a way to upload somewhere so you can get it. I think my catalog .pdf is from 2013
-Carl
DCal
Post by DCal »
In-Tech wrote: Sun Aug 29, 2021 7:41 am Yepper, I used to run around with a bunch of scallywags so we probably met somewhere, :lol:
Four of those scallywags rented our Mooresville NC track the week before Brainard and invited me out, the best time I've had at the drags in a while.
I did not find the pdf file but several pictures w/dimensions so I'll manage to figure something out. thanks
1980RS
Post by 1980RS »
I know on my 68 Firebird which has about the same hood clearance as a Camaro cowl hood I got a 1.5" (1" spacer and 1/2" nos plate) spacer setup under my hood with the GM drop base air cleaner.
DCal
Post by DCal »
1980RS wrote: Sat Sep 18, 2021 1:03 am I know on my 68 Firebird which has about the same hood clearance as a Camaro cowl hood I got a 1.5" (1" spacer and 1/2" nos plate) spacer setup under my hood with the GM drop base air cleaner.
Thank you very much, that's what I came up with too. Well I figured that I wasn't going to get a 2 inch there anyway. lol
1972ho
Post by 1972ho »
When I check my carburetor to hood clearance I mount my phone under the hood somewhere and close it with the video camera turned on.
In-Tech
Post by In-Tech »
1972ho wrote: Sun Dec 12, 2021 9:47 am When I check my carburetor to hood clearance I mount my phone under the hood somewhere and close it with the video camera turned on.
How many phones ya got, or I mean, how big a boy are ya :mrgreen:
-Carl
