How to flush a converter?
econo racer
Post by econo racer »
Can I flush my turbo 350 converter with out taking it some where?
Geoff2
Re: How to flush a converter?
Post by Geoff2 »
Yes!
Drill a 1/8" hole in the bottom & let the fluid drain. If you want to flush the system, put a temporary plug in the hole & refill.
Once you are finished flushing, fill the hole with a 1/8" pop rivet, smeared with silicon.
In-Tech
Post by In-Tech »
Or you can just do it how we do out here in the woods, put it upside down with a water hose sprayer set on kill and let it eat. Turn it over a couple times and fill with tractor supply solvent and repeat.
-Carl
econo racer
Where on the bottom of the converter? Doesn't it have like 150 lbs. pressure run thru it ? I keep spraying brake cleaner in it then dump. Has a little water in some how. I know because the 1st time cleaning it came out strawberry shake color. A pop rivet would really not leak? Should I put JB weld under the rivet?
dannobee
Post by dannobee »
Personally, I wouldn't use a rivet, although you can use a closed end rivet. Fords have a small boss welded on their converters with an 1/8" pipe plug for draining. I'd do something like that before a rivet, especially on a high rpm race car. Weld a washer opposite of the plug if you're worried about a balance issue.
You'll never get all of the oil out of a converter without a drain plug. I used to rebuild torque converters, so I kinda know.
Geoff2
Post by Geoff2 »
Chrysler also used drain plugs. Pathetic that GM didn't it....
BOOT
Post by BOOT »
I recently bought a New TCI converter that came with a drain plug. Was kinda surprised since I never seen one before but they put it on the outer back towards the outside, looked like 1/8 npt if I rem right. Imagine they did it that way so it could be drained in the car.
ChopperScott
Post by ChopperScott »
Be aware that drilling and adding a pipe plug may alter the balance and cause unwanted vibrations.
'73 Camaro Z/28 NETO/N
Chopper Air Port 917-589-1278
BOOT
Post by BOOT »
Prob a good idea to use an aluminum hollow plug, idk what TCI used but I'll assume it's balanced.
Geoff2
Post by Geoff2 »
1/8" NPT. That is what Chrysler used for years, don't know if they still do.
dannobee
Post by dannobee »
If you're really worried about balancing, put the pipe plug equally between two converter bolts and use a similar weight washer on the converter bolt opposite the plug. (Assuming your converter has 3 mounting lugs).
rcull
Post by rcull »
Maybe is am wrong, but I wouldn’t think balancing would be a problem. I would have expected it to balance like a fluid damper or a tire filled with flat proof.
1980RS
Post by 1980RS »
We always used an aluminum 1/8" pipe plug in the drain hole. Weighs nothing.
