Wanted - BBC 2.750" length pins
We're working on a project which seems to require 2.750" BBC pins. What do you have?
Re: Wanted - BBC 2.750" length pins
Precision Products in Arden , NC will make anything you need.
1-800-421-9150
1-800-421-9150
Check with mahle Motor sports.
Depending on weight they have several .990"pin options available. Just got some for a BB Mopar piston using a BBC rod.
They use wire locks but if you are using a single or dual spiro loc they should be fine but a regular c-clip may even work depending on the groove width.
