Collection of Used Parts
bolsa99
Post by bolsa99 » Fri Jul 27, 2018 2:24 pm
Afco Oil Cooler 15x9x2.5, used, good shape $100
Erson/PBM Solid Roller lifters RL981, used, about 15 nights $250
KSE Tandem X fuel/power steering pump, bellhousing mount, used about 40 nights $350
KSE fuel/power steering pump, bellhousing mount, older style, turns a little stiff, unknown nights, $150
HVH 1" 4 hole taper carb spacer, used $50
Bert Bellhousing, SBC, about 40 nights, no visible cracks I can see, no repairs, $250
Jesel Belt Drive Timing Set and cover, SBC, about 70 nights on it, $300
Wilson ported and polished Edelbrock 2925 intake, setup for 1205/1206 intake gasket $400
Comp Cams Wet Belt Timing setup, 20 nights, SBC, Used $100
Comp Cams 818-16 Solid Roller Lifters, unknown number of nights $100
ATI Aluminum Hub Dampner, part #917232, designed for belt drive cover, 7 3/8, used 35 nights, $150
Summers Gear Drive Timing set, unknown number of nights, chip missing on cam gear cam recess, $150
All items are used, paypal only, I can send pics of any items. Text 218-248-2099 for pics or questions. Most items were used on dirt modifieds or late models.
cgarb
Re: Collection of Used Parts
Post by cgarb » Tue Sep 11, 2018 10:31 pm
Is the Jesel belt drive for a standard 9.0 deck sbc engine? Standard crank C/L and standard crank snout?
rockosocko
Post by rockosocko » Wed Oct 17, 2018 2:08 am
Would like to know what you have left.
Pm sent on the timing components..
Thanks
E
