Wanted Dodge 2bbl intakes
ProPower engines
Post by ProPower engines » Sun Mar 03, 2019 2:42 pm
Hey guys
I am looking for some 2bbl intakes for a 318/360 suitable for a race engine that is restricted to a cast iron unported intake. Depending on the design I am looking at all options available.
Email me through the board and I will get back to you asap.
Thanks for looking
Re: Wanted Dodge 2bbl intakes
Post by PackardV8 » Sun Mar 03, 2019 2:59 pm
We've scrapped out several without any analysis of which might be best. When those who know tell us which years to look for, in a month or two the snow might melt enough to begin looking for one.
jack vines
ProPower engines
Post by ProPower engines » Mon Mar 04, 2019 4:26 pm
The best may be from the early 70's to about 78-79 era.
the intake I am really looking for is from a cop car in the mid 70's to mid 80's from the 360 engine.
This had a single barrel carb which was more like a single butterfly of flap but in a 2 bbl carb body design with a different base plate configuration but the carb and intake worked much much better then the largest 2bbl that was available.
The manifold had a open design on the carb mounting flange area which leads me to think they were specific to either marine or cop cars as there was a single barrel carb deal on chrysler marine engines as well.
Keep me posted when the snow melts. [-o<
Post by PackardV8 » Mon Mar 04, 2019 7:18 pm
Wow, that's one I don't believe we've ever seen. Shouldn't be difficult to spot.
jack vines
ProPower engines
Post by ProPower engines » Mon Mar 04, 2019 10:48 pm
They are still out there but not nearly as common as 40 years ago.
We had lots of the old cop cars come through the wrecking yard here over the years and the carbs were real popular for some reason I guess they were N L A from the dealer or rebuilders but the guys that had boats bought them up as OMC discontinued them. #-o
408swinger
Post by 408swinger » Thu Mar 07, 2019 12:22 am
Try forabodiesonly.com
I would be amazed if you dont get a bunch of responses.
ProPower engines
Post by ProPower engines » Sun Mar 10, 2019 11:27 pm
Thanks for the tip.
I forgot about that forum. =D>
Mummert
Post by Mummert » Wed Mar 20, 2019 4:31 am
I don't know if it is what you're talking about, but I remember seeing a single plane design 2 barrel cast iron oem manifold for the small dodge. I thought it was early 60's passenger car but maybe not. Anyone else familiar with this.
Mummert Y-blocks
ProPower engines
Post by ProPower engines » Sat Mar 23, 2019 3:15 am
There was a marine intake that was similar to the automotive intake. Either should work just fine so if ya see an intake please let me know.
Thanks again
Dave
Krooser
Post by Krooser » Thu Jun 27, 2019 11:16 pm
Seems like the mid-70's Dodge trucks had a higher rise type manifold.
APMachine
Post by APMachine » Fri Jun 28, 2019 10:33 pm
Do you have a casting number?
Krooser
Post by Krooser » Tue Aug 13, 2019 3:13 am
I found one 2bbl intake you can have....send me a pm.
prairiehotrodder
Post by prairiehotrodder » Mon Aug 19, 2019 10:23 am
I have 2 from 360's around 1975 - 1979.
