FRESH 362ci SOUTHERN ALLSTAR SPEC ENGINE
perfconn
Post by perfconn » Sat Jul 13, 2019 5:12 pm
1184 Bowtie block w/billet caps-4.185 bore
Winberg billet 3.290 stroke crank-38# w/283 mains & Honda rods
Carrillo 6.125 Honda journal rods-558 grams
CP custom pistons w/.470 dome & .043-.043-1.5mm rings
Brodix Southern All Star SPEC heads
HVH ported Edelbrock 2925 intake
2.055-1.60 titanium valves
PSI 1243 roller springs
Erson titanium retainers
Jesel 1.70-1.65 shaft rockers
Comp Cam billet roller cam w/4-7 swap
Jesel straight .937 keyway roller lifters
ATI 6.325 balancer
MSD 85501 distributor
MSD crank trigger
Scott plug wires
Cloyes timing set
Aluminum short water pump
Cast aluminum valve covers w/ Peterson pop off valve
Aluminum pulley set
Fabricated aluminum dry sump oil pan w/3 #12 fittings
2” Aluminum Super Sucker carburetor spacer
No laps on engine since 1st freshening
Pictures & dyno sheet available by email
Email: terry.marciaburnett@gmail.com
Phone: 865-567-6943
528.4 # Torque @ 5600rpm
639.2 hp @ 7200rpm
$8500.00
