Selling S.B. Ford 9.2" deck race engine
NOT ALLOWED: Selling or reselling in a retail manner.
Walter R. Malik
Post by Walter R. Malik »
This is the 9.2 deck, 383 cubic inch "Ford Racing Race Block" engine with C3 "Yates" heads which was only run in the Race Engine Contest.
It has an external wet sump oil system, 55mm roller cam bearings with Mike Jones roller cam; .775" valve lift - 262/272@.050".
Much more ...
I sold the tunnel ram but, I do have a single 4 barrel Ford Motorsport Racing manifold for it.
Make a serious offer.
rmcomprandy@yahoo.com
Walter R. Malik
Re: Selling S.B. Ford 9.2" deck race engine
Walter R. Malik wrote: Sat Apr 10, 2021 9:09 pm This is the 9.2 deck, 383 cubic inch "Ford Racing Race Block" engine with C3 "Yates" heads which was only run in the Race Engine Contest.
Much more ...
Ford NASCAR SVO M-6010-G351 block
and Ford NASCAR SVO AMS-6415 steel forging crankshaft with mains reduced to 302 size and rods reduced to Quad 4 Olds, (Honda), size.
738drvr
Post by 738drvr »
Are the heads port matched to the intake? Which intake is it?
Walter R. Malik
738drvr wrote: Thu Aug 12, 2021 5:11 pm Are the heads port matched to the intake? Which intake is it?
The intake is a Victor 351Y #2960 which is port matched to the heads at the roof & side walls.
It is the intake which was run with those NASCAR C3 heads when using a restrictor plate so, the port floor is higher.
Plenty of metal everywhere to port it however you wish.
Walter R. Malik
I have had several, laughable offers and actually accepted 2 but, one guy was talking out his butt and never called back and the other wanted to pay "on a time plan".
This is not a credit service. LOL
Walter R. Malik
I am just not gonna wait anymore for the buyer to finish transaction.
After accepting a deposit and 2 minimal payments, I am sending his money back; 4 months is long enough for him to get over his Christmas money responsibilities.
So, this engine is for sale again
1972ho
Post by 1972ho »
Did you ever come up with a price for this engine if so what is it I wouldn’t want to price someone else’s stuff.Like you said don’t low ball so if you price it that should knock off some of the low ball offers.
Walter R. Malik
1972ho wrote: Fri Apr 15, 2022 11:13 am Did you ever come up with a price for this engine if so what is it I wouldn’t want to price someone else’s stuff.Like you said don’t low ball so if you price it that should knock off some of the low ball offers.
Was thinking $10,000.00 however, the last offer I took was less but, after 4 months of just $500.00 payments, I gave him back his money.
Walter R. Malik
Walter R. Malik wrote: Thu Aug 19, 2021 11:49 am
It is a bout time to get this to the top again ...
A small block RACING engine is not very popular, I guess.
Walter R. Malik
This is such a good running engine, I would hate to take it apart to just sell the parts separately ...
Buddha
Post by Buddha »
Any idea what kind of power this makes?
Walter R. Malik
Buddha wrote: Mon Feb 06, 2023 7:57 pm Any idea what kind of power this makes?
With a tunnel ram manifold & 2 - 750 carbs it made 762 horsepower and 610 lb/ft of torque with an oxygenated gasoline ... VP 109.
I could only guess what a single 4 barrel would make.
1972ho
Post by 1972ho »
Man I sure wouldn’t mind picking up this engine from you.But I’ve bought some used engine and parts and sometimes things didn’t work out.Not saying your engine isn’t going to be a problem but.By the way do you have any other pictures of it to share in your advertisement and I wouldn’t need the intake I already have one for it.And what state would it ship from I’m in Southern California.
Buddha
Post by Buddha »
Walter, Do you know what the cc of the chambers? Friend wants to put this in an occasionally driven street car, and the thought is to reduce the c/r to something a little more pump gas friendly like 10.5 or 11. My thoughts are to increase the chamber size and/ or use a little thicker gasket. Do you think this is doable?
Thanks, Buddha
Walter R. Malik
Buddha wrote: Tue Feb 14, 2023 4:02 am Walter, Do you know what the cc of the chambers? Friend wants to put this in an occasionally driven street car, and the thought is to reduce the c/r to something a little more pump gas friendly like 10.5 or 11. My thoughts are to increase the chamber size and/ or use a little thicker gasket. Do you think this is doable?
Thanks, Buddha
The chambers are very shallow on these NASCAR heads at 41 cc's.
This is not a street/strip type engine.
