wtb 1964-67 v8 factory chevy II front sump oilpan.
- New Member
Looking for a front sump v8 pan for chevy II if anyone has one. Hoping maybe someone converted to the better rear sump pan and still has there original front sump pan they would part with.
Re: wtb 1964-67 v8 factory chevy II front sump oilpan.
you do know that the front sump pan uses a very hard to find special oil pump and screen???
- New Member
I have seen them pop up on ebay,, are you running a auto or stick???
- New Member
Stock m20 and and factory shifter . My factory 362 casting 327 block for the 66 nova I have, had to be freshly bored .060 now i have one cylinder #1 sonic tests ,098 on a spot one to two inches down in the bore on the major thrust side so I dont know what to do put it together and cross my fingers or possibly sleeve it and hope it doesnt screw up #3 cylinder roundness.
Have you tried Joe at Chevy 2 Only?
The pans are reproduced also.
Tom
Tom
- af2
Here you go..
https://gmclassics.com/part/oil-pan-v8- ... -kick-out/
GURU is only a name.
- New Member
Found one on the hamb ,he put a rear sump pan on and had the old original front sump pump and pickup $30.00. Which was fair I thought.
