reason for selling parts: Assembler installed cam bearings incorrectly, had to pull engine to inspect. Moving out of the 4 cylinder realm into the GM world where I belong. Cylinder head checked out fine and is at Wilkes Performance being reassembled.
Stinger Performance "CAS" setup for 2.3 sequential fueling, zero miles $400
Stinger Performance MS3X "PimpXS" plug and play engine management system (plus harness for Fox body or Ranger). Will control normal ecu functions as well as N2O, boost, bump box, PWM devices, etc. Pretty trick setup. $1200
1987 2.3T block and crank, decked to .005", ARP head and main studs, no road miles, idle tuning only, Crower 5.2 rods, 3.800 Diamond stock dish Forged pistons, TS AP steel top ring, ductile 2nd (1mm,1mm,2mm). Engine still looks and mics out new. $1500 obo
Fresh Dynamic Race Trans Mighty Mite C4 (Pro brake, rev man vb, zero miles), B&M Pro stick with correct gate (bell housing not included) $1500 obo
Quick Time RM-4057 bell housing, 2300 Lima Ford to C4, $600, (new- I mounted the tranny to it).
PTC 2.3 9" Boost converter (built for 408" Windsor, Kenny adjusted) stall to 4400 on brake $475
Boport stage III ported 87 Turbo Coupe head, 1.94/1.50 SS valves, Beehive springs, Hyd roller Boport 2.1 camshaft (.515 lift, 212/222 dur @ .050 on 114) $1500 firm
Fully ported and welded 135* rotated turbo coupe intake manifold by 40Bob, $350 obo
FID 1600 injectors (4), $375 obo
Cummins HX35 (8 blade, 58 lb/min) turbo, $400 obo
Custom 2.3 twin scroll header with SS down pipe, $500 obo
Serious inquiries only. Email for pics.
Ford 2.3 shortblock, Stg III head, Dynamic Mighty Mite C4
Re: Ford 2.3 shortblock, Stg III head, Dynamic Mighty Mite C4
Transmission, converter and shifter SOLD.
All else still available.
Engine (longblock) SOLD.
by long block
you mean head is gone also
