NEW 430ci ALL ALUMINUM SB2.2
NOT ALLOWED: Selling or reselling in a retail manner.
perfconn
Post by perfconn »
New 430ci ALL ALUMINUM SB2.2
Childress heads - no epoxy - no welding
44.4cc chambers
7mm 2.180 titanium intake valves - 50* seat
7mm 1.600 titanium exhaust valves - 55* seat
PSI 1582 springs
Titanium retainers
1.90 -1.85 Jesel shaft rockers
GM 617 intake ported by RCR
Magnesium valve covers w/oilers
Valley cover
PBM Aluminum block - 400 main - 50mm cam - 4 bolt billet main caps - 6 bolt rear main -9.200 deck .391 raised cam - spread pan rails - 4.135 bore
JE flat top pistons - 1.190 ch.- 531grams - .043-.043-3mm
Diamond .927 X .200 taper wall X 3" pins
Callies Ultra 6" X 2" H beam rods - 626grams
Callies Magnum 4" crank - 400mains - 1882 bob weight
Comp Cam 50mm 8620 billet cam
.776 intake lift - .755 exhaust lift
Jesel bushing style tiebar .904 DLC coated lifters
MSD crank trigger
MSD 85551 distributor
MSD 8.5mm plug wires
Bosch spark plugs
Dan Olson aluminum dry sump oil pan
Stewart water pump
Jones pulley set
ATI balancer
850 hp @ 68000rpm
681# torque @ 6200 rpm
Compression -14.33
Pictures are available by email
$22,500 cash
$24,000 w/Davinci 1.500 venturi gas billet carburetor
Phone: 865-567-6943
Email: terry.marciaburnett@gmail.com
perfconn
Re: NEW 430ci ALL ALUMINUM SB2.2
Post by perfconn »
Price dropped to $22,000 or $23,000 w/new Davinci carburetor.
perfconn
Post by perfconn »
Pictures for SB2.2
perfconn
Post by perfconn »
Still for sale.
perfconn
Post by perfconn »
Engine is $21,000 without carburetor.Engine was dynoed with 950cfm Stealth carburetor on Renegade 112 octane gas(non oxygenated) & Renegade 20w50 oil.
perfconn
Post by perfconn »
SOLD -SOLD - SOLD
