BBC 396cid 375HP 4-Bolt Main Block 1969
maxracesoftware
Post by maxracesoftware »
original complete Engine was purchased from Dickie Harrell Chevrolet
around 1969 , sent by Jet , i went to New Orleans airport to pick it up .
all i have left is the Block , everything else i sold many years ago
Blocks been sitting about 50 years in my Shed
i have a BBC 396cid 375HP 4-Bolt Main Block 1969
i want to sell .... wanting to find out what's it worth ???
Info :
Meaux's 396cid/375HP BBC 4-Bolt Mains
396cid = 4.094" x 3.760"
casting# 39552272
19W445814
T0310JL
T = Tonawanda
03 = March
10 = March 10th
1969
W = Willow Run, Michigan
Suffix Codes :
JL 1969 396 375 Chevy II SHP
JL 1969 396 375 Camaro SHP
SHP=Special High Performance
TH=Turbo HydraMatic
MaxRace Software
maxracesoftware
Re: BBC 396cid 375HP 4-Bolt Main Block 1969
Local Racer offered $1500.00
wants to pick it up this week !
i'll Post back if actually Sold .
MaxRace Software
maxracesoftware
SOLD ... to local Guy , going into 1972 SS ElCamino frame-off restoration , he picked it up an hour ago !
lightly cleaned the Block and Bores ... it miked :
4 Bores at 4.0935"
3 Bores at 4.0940"
1 Bore at 4.0945" which was Cylinder# 7
MaxRace Software
maxracesoftware
he's putting on Open Chamber aluminum Round Exh Ports on the Block
new Edelbrock Air Gap Dual Plane Manifold in box
new Sniper EFI Carb
new 700R4 transmission
3.73:1 Rear Gears
MaxRace Software
C.A.R.E.
Post by C.A.R.E. »
Shame someone didn’t buy it to put an original 69 396/375 car back to stock. But I hope the purchaser enjoys it.
You are only limited by your machinery and your imagination!
maxracesoftware
C.A.R.E. wrote: Wed Jun 29, 2022 8:05 am Shame someone didn’t buy it to put an original 69 396/375 car back to stock. But I hope the purchaser enjoys it.
he's going to get the Block further cleaned up back to looking perfect by another Shop ,
then decide whether to just lightly Hone it and keep it standard Bore or Bore +0.030" to 402cid ??
i told him i can Torque-Plate Hone the Block , or Bore it +0.030" for him
and can Deck and Square the Block if he wants ,
and if he gets another Shop to do it, and they want to Deck the Block,
make sure they leave the original Stamped ID on the Block, if they can't with their Machine ,
i can mill the Decks and leave the original Stamped ID portion on the Block alone , the Headgasket doesn't quite go that far .
MaxRace Software
scoob314
Post by scoob314 »
That partial Vin is from a 1969 nova i believe. More than likely a take out engine that DH did a 427 swap on.Should post it up on yenko.net, someone would probably sell a kidney for it if it's their original block. Otherwise you did ok at 1500.
