NEW 360ci TOPLESS OUTLAW - STEELBLOCK BANDIT ENGINE
Dart SHP 4.145 bore,350 mains,50mm,.904 bushed lifter block
Callies 3.335 stroke,350 mains,small journal rods crank
Callies ultra H - beam 6" rods
Brodix track 1 cnc ported 233cc aluminum heads
2.125 - 1.600 titanium valves
Edelbrock ported 2925 intake
CP 4.145 pistons
Comp cam 50mm 8620 billet cam
PSI XCE S01 valve springs
Jesel .904 lifters
Jesel 1.60 - 1.55 shaft rockers
7/16 - .165 wall pushrods
Edelbrock waterpump
Jones pulley set
MSD double pickup distributor
MSD crank trigger
Scott spark plug wires
Bosch sparkplugs
Dan Olson aluminum drysump oilpan
ATI balancer
Clements billet aluminum valve covers
13.6 compression
648hp @ 7300rpm
515 # torque @ 6300rpm
Valves - .016 hot
Timing 36*
Engine # PRE 344
$25,000.00
Pictures & dyno sheet can be emailed
Email: terry.marciaburnett@gmail.com
Phone : 865-567-6943[attachment=2]IMG_20220811_110957.jpg[/attachment][attachment=1]IMG_20220811_110631.jpg[/attachment][attachment=0]IMG_20220811_105335.jpg[/attachment]
NEW 360ci TOPLESS OUTLAW - STEEL BLOCK BANDIT ENGINE
Re: NEW 360ci TOPLESS OUTLAW - STEEL BLOCK BANDIT ENGINE
I also left out that it is the LS firing order
