Bridgeport R8 head skimming
gunt
Post by gunt » Sun Feb 10, 2019 3:24 pm
bridgeport r8 for skimming heads and blocks metal and alloy , either that or recommendations for where to buy and or make ,
cheers
Dave Koehler
Re: Bridgeport R8 head skimming
Post by Dave Koehler » Mon Feb 11, 2019 8:41 am
As far as making your own you can certainly do that.
Google will be your friend.
Here are a couple places among many that come to mind.
https://www.subtool.com/st/fcs_fly_cutter_sets.html
https://www.pinnacleflycutter.com/
bill jones
Post by bill jones » Mon Feb 11, 2019 11:42 am
---the R8 shank that fits into the quill is pretty small and not very sturdy---so there would surely be some distortion trying to happen at every hit of the cutter.
---having a multiple head cutter such as 6 cutters would allow each cutter to take 1/6th of the cutting load if they were adjusted pretty decent---so the distortion at cutter would be greatly reduced.
---this link below shows a couple of pictures of how I built my cutter head for my #30 taper quill---which is a much stronger snout design.
---it takes some effort to get the cutters dialed in perfect or even to within a couple of thou---but this cast iron flywheel has worked for me since 1996.
---I felt the cutter diameter needed to be pretty large to get a nice sweep---so my cutter diameter ends up at 9.8".
---I have my mill head tilted precisely up on the trailing edge .0015" so the trailing cutters don't leave a waffle pattern as they come across over the freshly milled surface.
---the joint between your R8 mandrel choice for the adaption of your cutter head really needs to be 100% secure and failure proof.
http://ryanbrownracing.com/Bill_Jones_Page_1.html
---this link has a little more about my way of thinking on the cutter head operation.
https://www.speed-talk.com/forum/viewtopic.ph ... 7&start=30
gunt
Post by gunt » Mon Feb 11, 2019 4:34 pm
Hi
I'v long read all your items , thanks for the imput , that was always one thought i had as to why not use the multi tip cutters somonlly seen , also any views on stone as i have heard of several who using the big name machines ruin an expensive head over " there must have been a hard / soft spot and the cutter dug in " , this could be a myth too.
Bill I haven't used this mill yet I'm trying to get a semi retired guy in and build from there , but no point in having a guy and no tooling , are you saying i can mount your setup to my head eliminating the R8 or you are using a mill with a different head , would you consider making another cutter ?
Thanks Dave , I had seen these and forgotten again , looks like what i'm thinking, I like the mounting plate as it should suit the majority of engines i work on
Anyone any thoughts on this
http://jamisonequipment.com/machine/cbn ... e-machines
bill jones
Post by bill jones » Mon Feb 11, 2019 5:39 pm
---My stuff fits a #30NMTB spindle---which has a larger taper and larger diameter at the large end of the taper.
---I just showed it because it's what I built---because I didn't have $1300 for something like the Jamison cutter and I know nothing about running a single high speed cutter.
---the R8 maximum diameter of the largest end of the R8 piece inside the quill is only something like maybe 1.250"---so the cutter plate can't be real sturdy is you making it with a 3/4" shank to fit into an end mill holder.
---so you need some special R8 part that is solid and protrudes down to mount your cutter plate to---maybe something with a circular threaded flange or like large #4 Morse taper with a key and a single mounting bolt---then build your own hub to fit your large diameter cutter head plate.
---my deal made out of a Chevy flywheel is pretty crude but it works really well with no problems.
---the large diamond wheel needs to be run easy on the cut depth---it's best purpose is on cast iron diesel heads that have the hardened "pre-cups" to deal with.
---personally I would not use steel for the large diameter cutter plate---I'd rather make it out of cast iron to eliminate any vibrations or harmonics getting onto the surfaces being machined---so a simple cast iron flywheel seemed a good choice to me.
---I had to machine a couple of the critical mounting surfaces of my #30 hub adapter for the Chevy flywheel---and I did those machining processes on the hub right on the mill from underneath with the cutter's mounted in the mill vise.
---I really don't have any plan for what it would take to build an R8 cutter plate.
---if I had to do mine again I would probably use a larger diameter flywheel that the SBC one I used---to get another 1" or so cutter diameter---but there's really nothing wrong the diameter I'm using now--so far.
---I also have about a 6" diameter flywheel CUP stone mounted on a different mandrel---that I use for when I need to do a flywheel or like the SBC & BBC rear main cap pad where the oil pump sits.
---this cup wheel is really coarse but it actually leaves a pretty nice surface on cast iron---don't think it'd try it on aluminum though.
---I have several other multi-tip cutter heads that I use like for milling intake flanges of intake ports where the valve cover rails protrude along the top---one cuts about a 6" diameter and the other cuts about a 8" diameter.
JRice
Post by JRice » Tue Feb 12, 2019 1:20 pm
Get one of these.
I use one on my DCM Machining center and it works good. Can get a 14-18 RA finish on a LS Cylinder Head. I spin it 850rpm and around 7in a min.
http://bigflycutter.com/site/mobile?url ... e.php#2756
gunt
Post by gunt » Sun Feb 17, 2019 3:38 pm
Just remembered i had a few dvd's from these guys, any one have one or a basic yes or no would help , seam like good guys at it a long time
https://www.precisionmeasure.com/produc ... ture-only/
gofaster
Post by gofaster » Mon Feb 18, 2019 1:39 pm
I use a Precision Measurement Supply 8" fly cutter with the 1" stub arbor. It's a slow process but it leaves a nice finish that looks better than factory stock.
Jim McMahon
Heads1st
http://www.heads1st.com/
gunt
Post by gunt » Mon Feb 18, 2019 3:24 pm
Hi
Thnaks , I seen only 1 left so i went with it , for what it is its gona come in handy either way ,
Cheers
In-Tech
Post by In-Tech » Mon Feb 18, 2019 5:11 pm
Get one of these.
404 (Page Not Found) Error
edit, I backed up and found it on the home page http://bigflycutter.com/ , that cutter looks nice. What are its drawbacks? I haven't looked at it close enough, is it big enough and/or capable of doing interrupted cut such as an alum deck with sleeves? LS?
Thanks
-Carl
jeremyinlinepro
Post by jeremyinlinepro » Mon Feb 18, 2019 7:26 pm
I have the big fly cutter and use it in a Cat40 cnc mill. I bought a pcd bit and the finish is the nicest I have ever seen on aluminum cylinder heads. Iron blocks have been fine. Aluminum blocks with stock sleeves I have been able to get an ok finish on but I have not been able to use it with aftermarket ductile iron sleeves in an aluminum block. I tried tons of different bits, speeds, and feeds and I just can’t get it to work right. I think the cutter may not be stiff enough for the ductile iron.
In-Tech
Post by In-Tech » Mon Feb 18, 2019 8:09 pm
Thanks for the reply.
-Carl
JRice
Post by JRice » Mon Feb 18, 2019 11:43 pm
I’ve ran into the same issue on aftermarket sleeves. I also have a 12in steel body cutter that came with my DCM that I use for the sleeved blocks. (Just don’t like installing the heavy son of a gun In the spindle)
