WTB Efilve Flashscan V2
derkscustomcars
Post by derkscustomcars » Fri Feb 22, 2019 12:11 pm
Hello,
I fried the usb part of mine so no more communication with laptop, i can still use it with the unlimited license i have for certain ECM's
In order for me to use custom operating systems, i need it to be hooked up to my computer. Anyone have one laying around?
I know i can buy a new one but i thought i'd try here first
thanks
In-Tech
Re: WTB Efilve Flashscan V2
Post by In-Tech » Tue Mar 05, 2019 4:42 am
Did you get this repaired? Is it just the usb connector or the ftdi chip? What happened?
-Carl
derkscustomcars
Post by derkscustomcars » Tue Mar 05, 2019 11:11 am
EFIlive says that Its non repairable, it still receives power over usb, not sure what happened. All i know is that it happened when i tried to benchflash an ECM and grabbed the wrong cord.
I opened it up and i tried to id the USB chip, but no luck.
Have any idea what i would be looking for?
In-Tech
Post by In-Tech » Tue Mar 05, 2019 11:17 am
I'd have to open mine up. What is a "wrong" usb cord?
-Carl
derkscustomcars
Post by derkscustomcars » Tue Mar 05, 2019 11:32 am
I meant that i uses the wrong bench harness, i was in a hurry. some ecms use the same plug but different pinout. usb cord is fine, just no communication with laptop.
In-Tech
Post by In-Tech » Mon Apr 08, 2019 7:38 pm
Hiya, did you ever get your ftdi chip? If you are having problems locating the correct chip, I probably have it in stock from back when I was doing a bit of usb vs 8192 baud stuff many years ago. I'm just curious how this turned out for you.
-Carl
