Page 1 of 1
Wanted: Bore Gage
Posted: Tue Mar 12, 2019 9:11 pm
by 83hurstguy
Looking to purchase a bore gage for measuring bearing clearances. Prefer a Sunnen if I can find one, would also consider a Mitutoyo 545 if someone has one.
Thanks in advance!
Re: Wanted: Bore Gage
Posted: Tue Mar 12, 2019 9:36 pm
by PackardV8
Yes, the Sunnen is best, but sort of a must to get the setting fixture with it, and that's bigger bucks.
I've got a Mitutoyo which might be for sale. I'll get photos for you.
jack
Posted: Tue Mar 12, 2019 9:38 pm
by 83hurstguy
Thanks Jack! I'll send you a PM.
Posted: Tue Mar 12, 2019 11:54 pm
by Charliesauto
83hurstguy wrote: ↑Tue Mar 12, 2019 9:11 pm
Thanks in advance!
If you find a Sunnen gage and want a setting fixture, I have an extra one, I would like to sell.
PM me if interested.
Posted: Wed Mar 13, 2019 6:42 am
by leahymtsps
PackardV8 wrote: ↑Tue Mar 12, 2019 9:36 pm
jack
Morning Jack
I own several of each and personally I don't think the Sunnen is any better than the 545 and in fact
the 545 leaves less of a mark on bearings.
Tom
Posted: Wed Mar 20, 2019 10:05 am
by 83hurstguy
Thanks for the responses so far, still looking if anybody else has one, particularly a Mitutoyo 545.
Posted: Wed Mar 20, 2019 10:56 am
by gofaster
I have a Mitutoyo 545-136 with tenths dial. PM me if you're still looking.
Posted: Sun Mar 31, 2019 10:05 pm
by 83hurstguy
Still looking... thanks to everyone for the responses so far. I would need the 545-135 to measure the 2-3" range.
Posted: Mon Apr 01, 2019 12:28 pm
by PackardV8
In looking over the two side by side, the Mitutoyo requiring three shafts to cover .75" - 6", where Sunnen can do it all with one would be the deciding factor for us.
The Sunnen setting fixture is additional cost, but again, so much more convenient to use, it's the best choice for shops.
jack vines
Posted: Tue Apr 02, 2019 6:23 am
by leahymtsps
Jack, exactly what Sunnen gauge will measure from .75" - 6"? It takes me 3 and they require 2 different setting fixtures
6000 -.740 - 1.19
9000 - 1.18 - 2
2000 - 2 - 6
The problem with used setting fixtures is threads can be worn in certain spots of their travel. In other words they can
be accurate at some diameters and not so much at others. Its no different than used mics.
Tom
Posted: Wed Apr 03, 2019 7:41 am
by 83hurstguy
Thanks everyone. I ended up finding a fair deal on a Sunnen GR from its original owner with light use, so it should be on its way. I'll post pics once I get it.
As Jack noted, buying an extra head for a Mitutoyo 545 (or just two gauges) to measure 2-6" was pricey, and finding it with sufficient length was also a challenge.
Posted: Sun Apr 07, 2019 4:30 pm
by 83hurstguy
Here’s the Sunnen gauge I purchased. It’s older (has metal case) but definitely has very minimal/light use, don’t really see wear on anything. There’s no model number on it that I see externally, but based on the 12” length and retractable feature, I’m guessing it’s a GR-2121. Anything else to check on these?
Posted: Sun Apr 07, 2019 9:00 pm
by gofaster
It looks a lot like my GA-2125, (mine doesn't have the retract feature). Very nice find. Make sure it reads the same after you retract and release a few times in a ring gage or a test bore. One of my smaller GR-6000 Sunnen gauges started to get inconsistent many years ago and I sent it back to them for repair. I haven't had any trouble with it since. Dirt and gravity are common problems, keep them clean and don't drop them.
Posted: Mon Apr 08, 2019 2:22 pm
by 83hurstguy
Thanks Jim. I did check it a few times, and it seemed to be repeatable.
