In case anyone is interested this is from 5the AERA BOARD
THERE IS A FEW HARD TO LOCATE ITEMS HERE THOUGH SOME ONE MAY MAKE USE OF THEM.
Contact me via email baltheadworks@verizon.net with Equipment in the Subject Line or call 410/876-5050 with any questions. All equipment is in good working condition.
DCM Tech HB 3800, Surfacer with stair step clamping fixture , block fixtures & cutters---------------------18,995
NEWEN G11. W/ Rollover fixture, vacuum tester and complete tooling --------------------------------------------22,999
AXE TB-10, Parts tumbler w/spare basket and media---------------------------------------------------------------------1,299
Peterson, RG-1203, Belt sander/platen grinder------------------------------------------------------------------------------2,995
DELTA Pressure tester, #6000 w/7 plates and cart w/accessories ---------------------------------------------------2,499
ABS, PC425-1. Downdraft cabinet-----------------------------------------------------------------------------------------------2,995
ULTRASONICS Parts cleaner, 35 x 22 -----------------------------------------------------------------------------------------2,400
SUNNEN, TS-100, Tool sharpener,-----------------------------------------------------------------------------------------------630
SUNNEN, HS-60. Guide sizing and seat repair bench --------------------------------------------------------------------3,300
SUNNEN, P310, Valve guide dial bore gauge --------------------------------------------------------------------------------795
ABS, Camshaft/valve stem polisher --------------------------------------------------------------------------------------------2,995
Tig Welder, L-Tech, 300 AMP, 60% duty cycle w/liquid cooler --------------------------------------------------------1,800
Shop equipment from AERA Forum
Re: Shop equipment from AERA Forum
Here is a link tot he forums. http://aera.boardhost.com/index.php
