Protect new garage walls
Heat/AC, electrical, lighting, flooring, design, construction, photos...
winterhoff
Post by winterhoff » Sun May 12, 2019 9:51 am
Looking to find a way to protect new drywall in new construction for hanging rakes and shovels as not to hear up the drywall over time
any input appreciated
exhaustgases
Re: Protect new garage walls
Post by exhaustgases » Sun May 12, 2019 4:30 pm
Using the correct dry wall helps. All new apartments around here are built with Densglass. It has fiberglass on the outside and is moisture and very fire resistant.
SupStk
Post by SupStk » Sun May 12, 2019 9:58 pm
In the home garage I installed Pro-Rib steel roofing along bottom of walls in the area I work. Layed it so the ribs run horizontal and the panels are about 38" tall. That seems to be the area that takes the worst beating. They do good defecting sparks from welding and grinding and a person can clean that area with a pressure washer.
Monty Frerichs
B&M Machine
6.50camaro
Post by 6.50camaro » Fri May 17, 2019 8:45 am
1/4" hard board or it used to be called masonite screwed over top the sheetrock prime and paint to match .smooth finish takes paint well cleans good. Leave screws exposed , with washers like trim screws in car interiors so you can replace it when it gets to beat up. Dan
rcull
Post by rcull » Thu Jul 11, 2019 6:19 pm
A lot of new garages/shops around here are starting to use metal roofing around here. It looks real nice when finished, choose the color you want, usually white, no paint required. Bright and fire resistant. You can use it on the roof too!
Cassidy
Post by Cassidy » Sun Aug 11, 2019 9:03 pm
You may want to check out fiberglass reinforced panels. They're cheaper than metal and give better protection than plywood.
