Picture posting help
cjperformance
Post by cjperformance » Thu Mar 24, 2016 7:03 pm
Hi, can someone please tell me an easy way to post pics here from a Galaxy S6 phone. Thanks
Craig.
emsvitil
Re: Picture posting help
Post by emsvitil » Thu Mar 24, 2016 7:10 pm
Put the pictures in a photobucket or equivalent account
then use 'img' code to display
[img} "link to photo" [/img}
I changed the trailing ] to } so you can see
Ed
engineczar
Post by engineczar » Thu Mar 24, 2016 7:49 pm
After hitting post reply you'll see a tab below the text box that says upload attachment. Pick on it.
Then pick where it says choose file. You should get this popup
Pick documents.
Find the photo you want to upload and pick it.
It will go back to the previous screen, pick add the file.
From there it will be an attachment. If you pick place inline it will appear as a picture and not just an attachment.
Also in the options make sure "disable BBCode" is unchecked.
cjperformance
Post by cjperformance » Mon Mar 28, 2016 7:57 am
Thanks for the info. I have tried the second method and a couple time its worked but mostly says the file is too large and i have no idea how to change this. I have not looked at the bbcode check part.
Craig.
cjperformance
Post by cjperformance » Mon Mar 28, 2016 8:03 am
I just posted a screenshot of what ST tells me when I try to post a pic! Obviously the screenshot must be a smaller file to allow it to work as a couple other pics ive posted must have been. I need to work out how to change the pic/file size?
Craig.
cjperformance
Post by cjperformance » Mon Mar 28, 2016 8:08 am
Ah! I found an app named 'Photo resizer' which seems to work ok but the pic loses some fine detail
Craig.
speedtalk
Site Admin
Site Admin
Post by speedtalk » Mon Mar 28, 2016 8:27 am
Yes, please be kind to the server - reduce image file size.
In Memory of Don Terrill
SpeedTalk Owner/Admin
cjperformance
Post by cjperformance » Mon Mar 28, 2016 8:35 am
speedtalk wrote:Yes, please be kind to the server - reduce image file size.
:D im trying!
Craig.
