Electric motor vs. Gas engine
Carnut1
Post by Carnut1 »
Not the same as the motors in electric cars but impressive anyway. 200 horsepower 480 volt 3 phase electric motor. Height 5 ft weight estimate 1000 lbs. This is a very efficient motor that is speed controlled by a vfd. Produces 100 percent available torque at zero rpm. This monster fills a 20" water pipe. What are they using in the new electric cars?
631-816-4911
9:00am - 9:00pm EST
ap72
Re: Electric motor vs. Gas engine
Post by ap72 »
About 10% of all power generated in the US goes towards pumping water. You should've seen the monsters I've dealt with at power plants and water treatment facilities. They feed 6' diameter pipes.
LOL, according to the post count I'm an "expert." The only thing I'm an expert at is asking questions.
77cruiser
Post by 77cruiser »
No porting to do.
We had some big uns in the paper mill I worked at too.
Couple thousand HP DC drive to pump up to 43000 gal./min.
5000 HP on vacuum pumps, dimmed the lights a bit when you hit the start button on those. 8)
Jim
Carnut1
Post by Carnut1 »
77cruiser wrote:No porting to do.
LOVE IT. Too bad you can't port them.
631-816-4911
9:00am - 9:00pm EST
Carnut1
Post by Carnut1 »
I am sure they dimmed the lights in the whole area!
631-816-4911
9:00am - 9:00pm EST
Truckedup
Post by Truckedup »
I had a career as a construction election and worked in all sorts of plants and factories... When a 400 HP motor starts the inrush of current makes the wires in the conduits stand up... but....To be in the generator room of a huge hospital during the test run of four Cat Diesel V12 engine powered generators....the engine run up against the governor and then the load is transferred , the engines bog just a touch before taking on the load with full rated HP... At an air show seeing the start up of 2000 plus cubic inch radial engines.....Dressed in animals hides clinging to a naked frame motorcycle propelled by fire at high speeds....The intense idle of a fine tuned V8.....Internal combustion is sight sound and feel...And unrefined in a world of molded plastic....
Post by MadBill »
NASA's Ames Research Center wind tunnel uses six 22,500 HP fan motors..
https://www.youtube.com/watch?v=WM55pcAL4bA
77cruiser
Post by 77cruiser »
MadBill wrote:NASA's Ames Research Center wind tunnel uses six 22,500 HP fan motors..
That would be like at 1:50 on this.
https://www.youtube.com/watch?v=0ar-__ub0rc
Jim
Post by pdq67 »
I got to see these years ago before they were shut down.
Northwest Steel and Wire, Sterling, IL.
"By 1968 NWSW installed a massive 250 ton furnace but it was during the 1970s that the scale of the furnaces at the Sterling plant became truly enormous. In 1971 and 1976 two 400 ton Electro-Melt furnaces were put in place, by George F Reitzel Electric. Those were the largest furnaces in the world at the time. A third furnace was converted to 400 ton capacity in 1979. In the same year NWSW employed 4,678 people, the highest number it ever employed as Whiteside County's largest industry."
I was told that when these kicked in, the north part of IL dimmed!!
Carnut1
Post by Carnut1 »
Truckedup wrote:I had a career as a construction election and worked in all sorts of plants and factories... When a 400 HP motor starts the inrush of current makes the wires in the conduits stand up... but....To be in the generator room of a huge hospital during the test run of four Cat Diesel V12 engine powered generators....the engine run up against the governor and then the load is transferred , the engines bog just a touch before taking on the load with full rated HP... At an air show seeing the start up of 2000 plus cubic inch radial engines.....Dressed in animals hides clinging to a naked frame motorcycle propelled by fire at high speeds....The intense idle of a fine tuned V8.....Internal combustion is sight sound and feel...And unrefined in a world of molded plastic....
I have run gen tests for a hospital and those things scream. The two cycle Detroit diesels will deafen you.
631-816-4911
9:00am - 9:00pm EST
BBO Omega
Post by BBO Omega »
Our shop in Chesapeake VA has the capability of servicing up to a 18,000hp AC Motor . We routinely service units in the 10,000 - 12,000hp range .
73 Omega, 468 BBO, 4.185 ICON Pistons,RR/Wenzler Heads with HS 1.7 rockers and PAC 1220X Springs,J&S 5-main Halo with Billet Caps, .590I .580E 242I 256E HR Cam, 1000hp Carb,2" x 3 1/2" headers,Coan 2900rpm Conv.,TH400,3.73 12 bolt,11.32/118
Greenlight
Post by Greenlight »
They claim this system added 400 lb. ft. of torque to your existing engine. The electric motor installs between the transmission an rear axle (using a shorter drive shaft) and can be used as a stand alone electric system or in conjunction with the vehicles engine.
http://www.evaos.com/products.html
Project Greenlight
Brian P
Post by Brian P »
The electric motors in electric cars aren't quite that big (LOL), they're typically liquid-cooled because of the power density, and they spin faster.
Anyone who has not had a ride in a Tesla Model S - preferably a P85D or P90D, the high performance all wheel drive version ... you owe it to yourself to give one a go. They are most impressive.
Jagdpanzer
Post by Jagdpanzer »
Here is a cross section of our MAN B&W 12S90ME-C Mark 9.2 engine type.
The 12 cylinder two-stroke diesel engine is rated at 105,720 hp @ 84 rpm and powers this 19,000 TEU container ship which is currently the largest in the world:
Sparksalot
Post by Sparksalot »
Just for fun I'll weigh in. When I worked at NASA Ames in the early 60s the Unitary Wind Tunnel had 180,000 hp worth of electric motors driving the compressor to just under sonic speed at the tips of the compressor section blades. It was later upgraded to 240,000 hp.
It took coordination with the electric utility to be able to run the beast. The original 40x80 tunnel that begat the larger test section tunnel mentioned above is a wimp power wise, it always was. Big though...
