Electric motor vs. Gas engine
dave brode
Re: Electric motor vs. Gas engine
Post by dave brode »
[quote="Brian P"]wrote;
Problem with wind power is convincing the NIMBYs. Big problem in our area.
As it should be. I trust that you do not live within ear shot of a turbine. Or in the flicker path.
Please, No - would not exist w/o lobbyists waving checks and the resulting subsidies from my tax dollars wind turbines- In My Back Yard.
Dave
https://www.facebook.com/SaveDansMountain
Post by MadBill »
Brian P wrote:Random thoughts about "efficiency" on EVs ...
If you are hung up on using fossil fuel then it's possible that well-to-wheels might not be all that different from using a combustion engine in the car.
BUT.
Coal is on the way out. Ontario (Canada) no longer has any coal-fired generating plants. We are about 50% nuclear 25% hydroelectric ~5% renewables (mostly wind), and the rest is natural gas. .
Speaking of ''Renewables a great example of the need to look at the details is the conversion of a coal-fired plant in Northwestern Ontario to natural gas... no wait, maybe not....err, yes NG it is! -...ahh, on fourth thought maybe not, lets go for a win-win-win by using biomass; the area has a burgeoning forest industry!
So, see how long it takes you to find the buried info in this: https://en.wikipedia.org/wiki/Thunder_B ... ng_Station ,which casually mentions that a) it burns fuel pellets imported from NORWAY #-o at enormous cost, making it by far the most expensive $/KW plant in Canada and b) to minimize the bleed of red ink, it is mandated to buy no more than 15,000 tons of fuel per year, leaving the plant operating at TWO PERCENT of capacity. .
289nate
Post by 289nate »
Whichever has the most HP will have the potential to be the quickest. Even if you're just racing from a stop to 60 feet.
Carnut1
Post by Carnut1 »
289nate wrote:Whichever has the most HP will have the potential to be the quickest. Even if you're just racing from a stop to 60 feet.
Would that be hp or torque?
631-816-4911
9:00am - 9:00pm EST
289nate
Post by 289nate »
I said HP. HP is calculated from torque. So torque and rpm if that helps you. As an example, I'll take 500 lb-ft at 6,000 rpm over 550 lb-ft at 2,000 rpm any day of the week and have the potential to KILL the other person accelerating to any specific mph. I'll also take my 400'ish HP 6.2L SUV engine over my 6.6L 360'ish HP Duramax diesel engine for potential acceleration to a certain mph even though the Duramax has a HUGE torque advantage.
Carnut1
Post by Carnut1 »
Ic engines and electric motors have completely different torque curves and are difficult to compare. Totally different animals. The question is could the low rpm torque still out accelerate the high rpm torque if geared right?
631-816-4911
9:00am - 9:00pm EST
Post by MadBill »
Carnut1 wrote:...The question is could the low rpm torque still out accelerate the high rpm torque if geared right?
It could if both were single-geared.
289nate
Post by 289nate »
The electric motor should have a flat HP curve (no such thing as max hp from 0 rpm though). That would result in a direct drive with a gear ratio set for a specific mph. Any kind of multi speed transmission would be pointless if you refer to the torque curve. What becomes available to you when you have torque and rpm? The ability to do work. It will become obvious if you use the mystical powers of math combined with what a properly set up drag application will consist of. It was hard for me to wrap my head around at first until I started doing the math.
289nate
Post by 289nate »
Yes. But why would they be??? The flat HP "curve" electric motor should be single geared as a multi speed transmission would be of zero use when it comes to torque at the tire which could be looked at as what accelerates the vehicle.
The internal combustion engine could use a two speed or a six speed clutchless manual depending on the power curve. Should never see the handicapped part of it's rpm range when done right. So give me the HP advantage every time if acceleration to a specific mph is the goal.
BBO Omega
Post by BBO Omega »
In a n AC Induction Motor application with a Toshiba G9 VFD, you achieve 250% Nameplate Torque from .2hz up .
73 Omega, 468 BBO, 4.185 ICON Pistons,RR/Wenzler Heads with HS 1.7 rockers and PAC 1220X Springs,J&S 5-main Halo with Billet Caps, .590I .580E 242I 256E HR Cam, 1000hp Carb,2" x 3 1/2" headers,Coan 2900rpm Conv.,TH400,3.73 12 bolt,11.32/118
289nate
Post by 289nate »
BBO Omega wrote:In a n AC Induction Motor application with a Toshiba G9 VFD, you achieve 250% Nameplate Torque from .2hz up .
What does the HP calculate out to be?
Post by pdq67 »
I want to say that a modern ultra supercritical steam fired power plant is something like 50 NET eff.
But please check me here.
I personally would use Nuke to heat one!
I have worked in a couple of BIG coal-fired power plants so know a bit about them.
1. TVA, Paradise plant. At one time it burned something like up to 20,000 tons of coal a day! And to put this in perspective, an aluminum coal car holds 120 tons!
2. Detroit Ed, Monroe, MI At one time this one was the largest one in the country.
Post by pdq67 »
Back again.
Does anybody SELL here in the good old USA a small corn-popper commuter 2-dr hatch stick tranny car?
It can also be a corn-popper diesel engine.
Newold1
Post by Newold1 »
I am not as electric motor knowledgeable as I am in IC engines, so can someone here share a little knowledge and explain here whether these new EV electric motors are running DC? and why as they are shown to be brushless motors how is that a benefit over brush and commutator motors. I have seen the control and power control systems in an EV and its a complicated looking piece of equipment. What is being done with the power output of the battery packs that this very involved control and conversion system accomplishes? Apparently from what I have learned these new EV electric motors are very efficient. How efficient?
Carnut1
Post by Carnut1 »
Last time I did some reading on modern electric drivetrain was 3 phase induction motor driven off a vfd.
631-816-4911
9:00am - 9:00pm EST
