Here is how to do it
exhaustgases
Re: Here is how to do it
Post by exhaustgases » Mon Jul 22, 2019 12:48 am
Nefario wrote:
Sun Jul 21, 2019 9:13 pm
exhaustgases wrote:
Sat Jul 20, 2019 1:32 pm
....So the 2.5 foot wire on the small winding coil takes 10.68 watts, and the 20 foot wire on the large coil takes 1.335 watts. So by this we see the big and more powerful magnetic force coil takes way less power to operate than the small less powerful one does. And I tested this over 30 years ago.
"The silence..." was taking a weekend break....
The 20-foot wire provides enough windings to create a stronger magnetic field. The shorter wire make fewer windings, generates fewer lines of force, and is converting more of the electric power to heat.
Tell it to GRT he's the expert. That has proven he knows nothing about electromagnets, yeah this is one thing I have tried, and its a proven fact.
Simple ohms law stuff. More mag force for less electrical power. Fact.
GRTfast
Post by GRTfast » Mon Jul 22, 2019 2:03 pm
For any solenoid there is an optimum arrangement. I don't think anyone is denying this. What I want you to clearly articulate is the following:
How does this show that an over unity motor is possible?
How does this show that a motor using only permanent magnets is possible?
exhaustgases
Post by exhaustgases » Mon Jul 22, 2019 8:11 pm
YOU NEVER CHECKED OUT THE LINK THAT SHOWED IT.
I've never mentioned over unity that's your thing. I have said to do it electrically. You could get more out of the electric motor than the electrical energy used. That is how Joe Newman's motors work, large coils with small amounts of electric power running them. Just like I showed you.
I've used the permanent magnets to show its magnetism doing the work in a motor, so figure out how to make magnetism efficiently.
Your in a box with your thinking, inventors have to think outside the established box to get anything done.
So for something interesting what is the resistance in the field and armature of the starter motor in your car?
John Wallace
Post by John Wallace » Mon Jul 22, 2019 8:27 pm
There are a few more things involved besides Ohm's Law.
Here's a link to some info.
Inductance
Faraday/Lenz/Kirchoff and many more apply.
Ignorance of the laws don't mean they don't apply.
John Wallace
Pontiac Power RULES !
www.wallaceracing.com
GRTfast
Post by GRTfast » Mon Jul 22, 2019 8:35 pm
Newman’s motor doesn’t do that, and you can’t build one that does. Magnets alone do no work. None. Zero. The provide a force. To use that force to do work, you’ve either got to put work in (push to magnets together with like poles facing each other), or you’ve got to change the field. The changing field is what does work, and it takes energy to make the field change. There is no motor that runs on permanent magnets alone, no matter how much you or any con man says there is.
Build one. Prove me wrong. Anything aside from that is a deflection. If you don’t have the money, maybe you can con some folks like your hero joe did.
exhaustgases
Post by exhaustgases » Fri Jul 26, 2019 1:56 pm
Inductance
Not in the experiment I did, steady state DC low voltage. So a radio person would not know that stuff? And yeah that is why your electronic devices that use a transformer don't burn up. Inductive reactance.
Nefario
Post by Nefario » Sat Jul 27, 2019 9:45 am
Aha! A source! Here's some interesting reading..."One of Newman's amazing discoveries is that coils having many turns of wire generate a given magnetic field with a lower input current than coils with fewer turns. Well even Michael Faraday knew that. Next he claims that increasing the number of turns reduces the power used." Where has this been typed before??
http://www.phact.org/articles/free/newman.php
Dave
exhaustgases
Post by exhaustgases » Sat Aug 10, 2019 12:20 am
GRTfast
Post by GRTfast » Sun Aug 11, 2019 6:18 pm
By “here is how to do it”, are you referring to fleecing gullible people out of money using an idea that’s physically impossible?
exhaustgases
Post by exhaustgases » Wed Aug 14, 2019 6:40 pm
Its been done by many. Its a power device that does not fit the control structure narrative. Like with Tesla's warden cliff tower, no one that runs the electrical business wants people to have free electric power nor anyother free energy, funny they support the solar though . Solar is no problem with them because they know it is only a part time energy source.
GRTfast
Post by GRTfast » Wed Aug 14, 2019 6:53 pm
It’s a power device that doesn’t exist. There is no “free” energy. Force does not equal energy no matter what you say. You can not demonstrate that it does. You can however show videos made by con artists that fleece money out of the ignorant and gullible.
If your claims were true, wouldn’t you think that power plants would use this technology in order to not have to buy any fuel, then keep selling the power to make insane profits? Instead they use turbines operating at around 60-65% efficiency (shaft work out/heat in) and generators operating at 99% efficiency (power out/shaft work in).
gruntguru
Post by gruntguru » Wed Aug 14, 2019 11:53 pm
The real difference is that energy from the sun is real and anything that delivers energy from nothing is fantasy.
exhaustgases
Post by exhaustgases » Thu Aug 15, 2019 5:34 pm
Every day millions of magnet motors deliver energy. They even start all gasoline and diesel engines, turbines as well. Magnetic force is not a fantasy.
gruntguru
Post by gruntguru » Thu Aug 15, 2019 6:16 pm
Big difference. "Magnet motors" need electric energy as an input - to generate mechanical energy (work) as an output. The input energy is ALWAYS larger than the useful output.
The "fantasy" is a motor that can do useful mechanical work - without any energy input.
Anyone who thinks they know better than the millions of engineers and scientists who have spent entire careers optimising the efficiency of electrical machines and FULLY UNDERSTAND the underlying physics is living in a world of fantasy.
GRTfast
Post by GRTfast » Fri Aug 16, 2019 4:28 pm
..But none of those motors run on permanent magnets alone. ](*,)
