TorqueMaster cam program update
Moderator: David Vizard
Stan Weiss
Re: TorqueMaster cam program update
Post by Stan Weiss »
CMIdiesel47448 wrote: Mon Aug 10, 2020 1:34 pm I'm getting an error every time I try to download the zip file. Any thoughts?
Also, assuming I can get this resolved, anyone know the "Induction Length" that should be used for a Super Victor EFI (29245) manifold?
Thanks, Damon
Damon,
What error are you getting. I just click the link and had no problems.
skinny z
Post by skinny z »
Thanks, Damon
Seeing as it may be modelled after the traditional Super Vic (non EFI), you may find that info at Speier'S website.
http://speierracingheads.com/manifold-lengths.html
skinny z
Post by skinny z »
Further to the above, add to the manifold runner length the length of the intake port on the particular head you're using.
I think you'll find though the intake tract part of the program doesn't physically change the cam spec generated. It's more of a tool for determining where a given intake length will make peak torque. It's then a matter of manipulating that length to work with the cam.
At least that's how my free trial version of TM played out.
That, and a great deal of resistance from the resident internet forum experts.
CMIdiesel47448
Post by CMIdiesel47448 »
Thank you Stan, worked fine today...
CMIdiesel47448
Thanks skinnyz!
skinny z
Post by skinny z »
> Thanks skinnyz!
I'll be interested in your feedback on TM.
It was a hard sell for just about anybody I engaged with regarding it's functionality or accuracy. Personally I have a pretty good understanding but those on the outside looking in just tend to criticize.
CMIdiesel47448
Actually looks like that SRH stuff if all Chevy. Anyone have a good number for 2924/29245 (Super Victor 351W) combined with AFR 220 Competition head? Assume it should be pretty close to the DV 408 build from several years ago. This is a 408W as well...
Thanks, Damon
> Thanks, Damon
Stan Weiss
I have done some housekeeping in this thread. The trail programs were all outdated and would not run anymore, so I removed them . The software User manual was also outdated and I removed it also. I have uploaded the latest User manual in this post.
tmc.pdf
skinny z
Post by skinny z »
Hi Stan
What's the latest with Torque Master?
It seems that the original webstore is no longer. I'd be interested in another go around with the program.
Thanks.
Kevin
Stan Weiss
skinny z wrote: Sat Dec 03, 2022 10:54 am Hi Stan
Thanks.
Kevin,
Yes, David's web site is down. I am not sure when there will anything up and running to replace it.
skinny z
Post by skinny z »
THAT is unfortunate.
Kevin
Stan Weiss
I am not sure how long it will be before David can get something done.
I have put something together as a temporary fix. It has a much different look and feel then the old web site but should get the job done for now,
skinny z
Post by skinny z »
> Stan
Thanks Stan.
Purchase pending.
Kevin
Stan Weiss
Right after the first of the year David had me stop selling the Torque Master Cams program.
I spoke with David last Friday. He said it as OK to sell the Torque Master Cams program BUT only doing SBC. I made the needed changes and it is now on the software store if you are interested. http://www.magneticlynx.com/DV/
Stan Weiss
The other 14 Day has expired and will no run. This is the install package for a new 14 Day version of TMC. Note at this time TMC only does SBC.
tmc_day14_6_7_4_setup.zip
